Vacuum gauge for a vacuum plate - any recommendations?
27 May 2023 18:58 #272280
by knipknap
Vacuum gauge for a vacuum plate - any recommendations? was created by knipknap
I built myself some vacuum plates like this:
To run this thing, I am considering one of these sets:
The reason being:
- They are very cheap.
- I want to use the container as a vacuum buffer so that the pump doesn't have to run the whole time.
I am missing one piece of the puzzle though: A vacuum gauge that I can connect to my interface card (MESA 7i76e).
Any recommendations?
The reason being:
- Thank you received: 5932
27 May 2023 21:36 #272287
Replied by tommylight on topic Vacuum gauge for a vacuum plate - any recommendations?
Wrong vacuum pump, you need the other type with high flow, this one is very low flow.
You can always use a normal air compressor as a vacuum pump, just reverse the in/out pipes.
And it has a much bigger buffer, just keep in mind it will not switch off as there is no pressure at the output anymore.
27 May 2023 21:40 #272288
by knipknap
Replied by knipknap on topic Vacuum gauge for a vacuum plate - any recommendations?
Are you sure that you aren't thinking of big vacum plates that allow for leakage? The small ones are made to be actually air-tight and do not need high flow.
27 May 2023 21:49 #272290
Your picture shows a 3D printed plate, those leak, always, although PETG should be OK for leaking with at least 5 perimeters.
Also, HIPS is very good at layer adhesion, but probably PETG is better for this.
Give it a try, might just work OK.
27 May 2023 21:51 #272291
by knipknap
It's not 3D printed, it's milled from HD-PE.
27 May 2023 22:49 #272295
Replied by rodw on topic Vacuum gauge for a vacuum plate - any recommendations?
Some things like this
www.aliexpress.com/item/1005005042915668....product.mainProduct
You should be able to find a LM358 low signal amplifier to bring it back up to near 24v for a Mesa analog input or simply use a Mesa THCAD-5 to read the voltage output which would be much more accurate.
28 May 2023 05:09 #272313
by itsme
Replied by itsme on topic Vacuum gauge for a vacuum plate - any recommendations?
This is what I would use:
www.aliexpress.com/item/10000142582204.html
28 May 2023 10:24 #272324
by knipknap
Thanks for the recommendations, these sensors are what I am looking for.
Though meanwhile I realized that the plan may not work out at all, because I am not sure whether the pump has a valve to keep the vacuum when turned off.
At least I may need more parts to make this work. I guess I'll start with buying only a pump and order additional stuff step by step to improve the overall setup.
28 May 2023 12:33 #272335
by itsme
I used a similar setup. The pump will leak a bit, but not that much.
The hysteresis setting of the sensor will deal with that...
28 May 2023 22:12 #272370
by knipknap
Cool, that's good to hear. I placed the order for the pump today and will see how it goes.
Moderators: cncbasher
Time to create page: 0.124 seconds
