SolidCam 2016 postprocessor for LinuxCNC 3 axis router
- RobertoMFS
03 Mar 2017 12:45 #88924
by RobertoMFS
SolidCam 2016 postprocessor for LinuxCNC 3 axis router was created by RobertoMFS
Hi guys, please can tell me what post processor to use in SolidCam 2016 for a LinuxCNC 3 axis router, working area 1100x660x15 mm
Thanks in advance.
Regards
Rob.
Thanks in advance.
Regards
Rob.
06 Mar 2017 23:30 #89115
Replied by andypugh on topic SolidCam 2016 postprocessor for LinuxCNC 3 axis router
Hard to say without the software or a list.
Is there one that mentions "EMC2" by any chance? That was the old name for linuxCNC.
30 Aug 2018 14:59 #116874
by DarkMonk
Replied by DarkMonk on topic SolidCam 2016 postprocessor for LinuxCNC 3 axis router
Any chance you got this figured out? I need the same post and the Github and generic Fanuc posts some people recommend throw a bunch of errors. I am using 2017 of SW and SC and 2.7 of LinuxCNC. I am just dong 3 axis milling.
Thank you for any help in advance and I hope your setup is running great.
06 Sep 2018 12:00 #117145
What errors? You might be able to make LinuxCNC work with those posts by re-mapping or adding G and M-codes.
Admittedly a post that worked without would be better.
07 Jun 2020 00:00 #170427
by Marcodi
Replied by Marcodi on topic SolidCam 2016 postprocessor for LinuxCNC 3 axis router
I have a solidcam post specifically written for linuxcnc and solidcam.
It's for a router. 3 axis
Router + 4th axis rotary: 4 axis.
The following user(s) said Thank You: DarkMonk
Moderators: Skullworks
Time to create page: 0.076 seconds
