Gedit high lighting
21 Sep 2017 04:32 #99194
by 64dodge
Gedit high lighting was created by 64dodge
I use cimco edit at work every day and like its high lighting. I have gedit set for ngc but is there a setting to high light code like cimco edit. X Y Z G M F codes different colors.
Tim
Tim
- Thank you received: 1369
21 Sep 2017 12:42 #99204
Replied by Todd Zuercher on topic Gedit high lighting
I am pretty sure you can do that. I haven't been using Gedit for a while, and I do not remember how to set it up. A quick google search for "highlighting Gedit" should quickly get you an answer.
22 Sep 2017 08:05 #99244
Replied by cmorley on topic Gedit high lighting
from linuxcnc iki:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Highlighting_In_Gedit
I havent tried it...
Chris M
Chris M
22 Sep 2017 08:13 #99245
seems to work on mint --I put it in /usr/share/gtksourceview-3.0/language-specs directory
Chris M
Chris M
23 Sep 2017 01:33 #99298
by 64dodge
Replied by 64dodge on topic Gedit high lighting
Thanks guys, I dont know much about this. I read late into the night trying to get my head around this.
The one thing Im not sure of is what part determines the color. This is from ngc.lang M is green.
<style _name="M-word" id="m_word" map-to="def:type"/>
<style _name="M-word (user)" id="m_word_u" map-to="def:type"/>
<context id="m" style-ref="m_word_u">
<match>m[\s\t]*1[\s\t]*[\d][\s\t]*[\d]</match>
</context>
I take it this is color [\s\t]*1[\s\t]*[\d][\s\t]*[\d]
<context id="m1" style-ref="m_word">
<match>m[\s\t]*[\d]+[\s\t]*[\d]?</match>
</context>
<context id="m2" style-ref="m_word">
<match>m</match>
</context>
</context>
</context>
<match>m</match>
</context>
23 Sep 2017 01:56 #99299
by 64dodge
The coding is alot different on other .lang files than ngc.lang
such as lex, ruby, modelica
Moderators: Skullworks
