request to proof read diagram
13 Sep 2011 08:31 #13154
request to proof read diagram was created by cmorley
13 Sep 2011 11:55 #13160
by BigJohnT
Replied by BigJohnT on topic Re:request to proof read diagram
I don't have a rotary so I don't know about the A... I would show the positive tool directions as that is usually what you see. Also I would make the tool direction arrows only point away from the center unless you made the centers of the lines cross and showed + and - directions. You might show the X axis through the center of the A so it is clear that the usual rotation is about the X... I think that is correct.
13 Sep 2011 17:00 #13178
by doug6949
Replied by doug6949 on topic Re:request to proof read diagram
According to the right hand rule, if you sight along an axis from the positive toward the origin then positive rotation is CCW. Your diagram shows CW rotation on the A axis.
HOWEVER (and it wasn't obvious at first):
Since the part is rotating and not the tool head, the vectors are inverted, just as X and Y are inverted. Think of the X axis moving to the left, generating a positive displacement of the tool with respect to the part - same concept. So it appears your rotation is correct.
I suppose this rule applies whether the rotary head is facing left or right.
Doug
Doug
14 Sep 2011 00:25 #13192
Replied by cmorley on topic Re:request to proof read diagram
Yes Doug the A axis caught me too i had the diagram show the tool rotation first then realized i was wrong.
I'm not sure if the direction arrows on the top right are clear that they indicate TOOL movement not TABLE movement but I can add that to the text not shown.
Yes John I think I will add the A indicator to the top right too but of course again it will show TOOL movement.
I will make changes and post again. Thanks guys
14 Sep 2011 11:07 #13196
by BigJohnT
I would still make the arrows all show positive tool movement in the upper right one, that seems to be what you always see when you google them or look in programming manuals for CNC machines.
15 Sep 2011 08:15 #13210
15 Sep 2011 11:42 #13211
by BigJohnT
Looking Good!
24 Jul 2012 02:47 #22363
by jy76
Replied by jy76 on topic Re:request to proof read diagram
did this end up in the wiki? or other docs it is very useful information and i think should be included in the getting started part of the manual thanx guys
24 Jul 2012 05:13 #22368
Its available in the PNCconf help page as well as a lathe diagram.
I'll leave it to John to decide if he would like it in the docs.
John drew the diagram for me.
I could add it to the Wiki if you think it is helpful.
24 Jul 2012 12:26 - 24 Jul 2012 14:47 #22389
by BigJohnT
Hi Chris,
Can you attach the lathe one without the text at the bottom? I thing both need to be in the "Important user Concepts"
Last edit: 24 Jul 2012 14:47 by BigJohnT.
Moderators: HansU
Time to create page: 0.334 seconds
