Touchy GUI - Where to find further documentation
30 Sep 2013 09:04 #39377
by Skippy1
Touchy GUI - Where to find further documentation was created by Skippy1
Hi all,
I've been running LinuxCNC on a router for a few years using the AXIS GUI and it does what I want. Just for chuckles, last week I installed a 17" touchscreen and set up the Touchy GUI and associated Start/SingleBlock/Abort buttons and MPG.
The change from AXIS to TOUCHY is not too bad, but I can't seem to find any way to do things which I did in AXIS, like changing offsets, and touching off tools. I've had a look at the LinuxCNC User and Integrator Manuals, and trawled the web, but the information on the TOUCHY interface is pretty sparse.
I would be thankful if someone could point me to some more reference material on the day-to-day use of Touchy?
Cheers, Steve
Cheers, Steve
30 Sep 2013 17:56 - 30 Sep 2013 17:57 #39384
by BigJohnT
Replied by BigJohnT on topic Touchy GUI - Where to find further documentation
Some of Touchy is not very intuitive and the manual is very terse on Touchy. Both offsets and tool touch off is a bit tricky to figure out but have the same basic steps.
Move your axis to the offset position you wish to set. In the MDI tab press Set Origin, enter the value for the axis you wish to set, then press the start button. It took me a while to figure that out.
I created a tool load macro on my mill to run T#1 M6 G43. I run this macro to load a tool then use the tool touch off.
Another thing I figured out is the stop button clears any error messages from the bottom of the screen.
JT
JT
Last edit: 30 Sep 2013 17:57 by BigJohnT.
01 Oct 2013 17:56 #39438
by Skippy1
Replied by Skippy1 on topic Touchy GUI - Where to find further documentation
Thanks John,
I'll have to have another fiddle next weekend.
cheers,
Steve
cheers,
Steve
07 Oct 2013 15:11 #39613
by Skippy1
Thanks again for the tip John. Touchy is working fine. Although, on the MDI page, what are the variables 'Q' and 'R' for? I had a fiddle with them, but only managed an error message of two.
Cheers,
Steve
Cheers,
Steve
07 Oct 2013 18:34 #39615
by BigJohnT
What did you touch to see Q and R?
I'm not sure what the difference is between G/XY and G/R0 but you get different options from each one.
JT
JT
08 Oct 2013 13:03 #39640
by Skippy1
Working from memory here, but I went to the MDI tab, selected 'Set Origin' and down the left side of the screen (in a vertical row) X, Y, Z, G, and R were accessible. Changing X Y or Z and pressing Start changed the G54 values. Changing a Q value and pressing Start did nothing. Doing the same to R produced a little error message about something being outside of the expected something of the other. (I half expected R to allow me to rotate the axis so many degrees.)
Just for information, I am using 2.5.3 configured with PnCConf.
Cheers,
Steve
Cheers,
Steve
08 Oct 2013 17:57 #39650
by BigJohnT
That must be an error in the program as G10 L20 does not have a Q or R word.
linuxcnc.org/docs/html/gcode/gcode.html#sec:G10-L20
JT
JT
07 Nov 2013 05:56 #40611
Replied by andypugh on topic Touchy GUI - Where to find further documentation
XY is for cartesian coordinates and R0 is for polar coordinates.I'm not sure what the difference is between G/XY and G/R0 but you get different options from each one.
07 Nov 2013 20:47 - 07 Nov 2013 21:06 #40631
by BigJohnT
Thanks Andy, I can't seem to make it do anything. If I press G/R0 then 0 then next nothing happens. If I press G/R0 then 1 then next I get F. If I press G/R0 then 2 then next I get the same prompts as G/XY give for an arc.
JT
JT
Last edit: 07 Nov 2013 21:06 by BigJohnT.
Moderators: HansU
Time to create page: 0.250 seconds
