Update to PNCCONF Doc - MESA config wizard
21 Jul 2017 21:21 - 21 Jul 2017 21:22 #96249
by RotarySMP
Update to PNCCONF Doc - MESA config wizard was created by RotarySMP
I was just reading up in the MESA Config wizard PNCCONF,
linuxcnc.org/docs/2.7/html/config/pncconf.html
and notice that the documentation is missing the following:
Section 3 - Gmoccapy is not described.
Section 6 - doesn't describe the timing for the 5i25 or 6i25 boards.
Mark
Mark
Last edit: 21 Jul 2017 21:22 by RotarySMP.
26 Jul 2017 15:13 #96479
Replied by andypugh on topic Update to PNCCONF Doc - MESA config wizard
The same is true in the latest documentation too:
linuxcnc.org/docs/html/config/pncconf.html
Do you feel like you know how to correct this?
27 Jul 2017 06:40 #96537
by RotarySMP
Replied by RotarySMP on topic Update to PNCCONF Doc - MESA config wizard
At present no, but would be happy to learn if that would help the community.
To Gmoccapy I'd add the following [before 4. External control]:
Gmoccapy
° designed to support a touch screen, but can also be used with a mouse, hardware button and MPG wheels
° modelled off commercial controls.
° includes 3D graphical window
° supports lathe mode for both normal and back tools, plasma cutters, up to 5 axis and non-cartesian machines.
° can be easily localised as labels are in a separate file
° integrates VCPs
° Supports NativeCAM integration
In section 5, can Gmoccapy be added to each sentence which refers to AXIS and Touchy?
In Section 6, with respect to the MESA board timing, I wonder whether we could ask the developers at MESA to suggest updated text. They they have a number of cards which are supported but not listed in this document. I just ordered from them, so maybe as a customer they will be conducive to this?
Mark
Gmoccapy
° integrates VCPs
Mark
27 Jul 2017 12:43 #96561
The documentation is in Asciidoc format here:
github.com/LinuxCNC/linuxcnc/tree/master/docs/src
You can edit directly on the web site, but I don't know if you can push (I can, but then I have push access).
I think you would need to click the other button and send a pull request.
asciidoclive.com/ seems to be a live asciidoc previewer which would allow you to check the formatting.
The following user(s) said Thank You: bymccoy
08 Aug 2017 11:37 #97168
by RotarySMP
There is already a GMoccapy description in the Gui sub folder. Should I just cut/paste it into the higher level doc?
Moderators: HansU
Time to create page: 0.123 seconds
