image to g-code documentation 1.4.11
25 Feb 2011 14:11 #7448
by dfink
image to g-code documentation 1.4.11 was created by dfink
In this document
linuxcnc.org/docs/html/gui_image-to-gcode.html#r1_4_11
It appears that the description of up milling and down milling is not correct. Up milling and down milling would be the direction of travel in relation to the rotation of the cutter to the material being cut.
a better explaination is provided here. I am sure the following description could be shortened to provide an adequate description
www.mfg.mtu.edu/cyberman/machining/trad/milling/index.html
25 Feb 2011 20:55 #7460
by BigJohnT
Replied by BigJohnT on topic Re:image to g-code documentation 1.4.11
In the Image to G Code section up and down milling is used in a different context than describing climb or conventional milling.
Moderators: HansU
Time to create page: 0.057 seconds
