Read This Before Posting!
04 Mar 2010 17:24 - 29 May 2013 18:19 #2183
by BigJohnT
Read This Before Posting! was created by BigJohnT
- Start a new post for your question instead of hijacking a post.
- Use pastebin.ca or similar for dmesg and other long printouts.
- Do Not use extended ascii characters or the message will be blank.
- Do Not use characters with accent marks or smart quotes or the message will be blank.
- Supported file types for uploading are patch, c, zip, txt, doc, gz, tgz, ngc, hal, ini, comp, dxf, clp, xml, pdf, stepconf, h, ui, glade, pncconf
- Maximum file or photo size is 1600kB.
Last edit: 29 May 2013 18:19 by BigJohnT.
The following user(s) said Thank You: tianmen8008, liangliming
The topic has been locked.
Time to create page: 0.109 seconds
