Option to move topic disappeared
18 Nov 2015 11:31 - 18 Nov 2015 15:48 #65417 by ArcEye
ArcEye created the topic: Option to move topic disappeared
Since the forum upgrade, no longer see option to move a topic to the correct section.
eg.
forum.linuxcnc.org/forum/18-computer/299...c2-7-ja8-custom-kins
has nothing to do with Computers and OS's and should probably be in Advanced Configuration or similar.
Because I am moderator for the section it has been wrongly placed in, I get a notification on every post which I cannot prevent, but can do nothing with it, save delete it.
EDIT: Now found the option under [moderate] which certainly was not intuitive to my mind, when there was an option to delete it completely on the main page
Last Edit: 18 Nov 2015 15:48 by ArcEye.
18 Nov 2015 16:11 #65441 by ArcEye
ArcEye replied the topic: Option to move topic disappeared
And if I try to send k-1 an email explaining why I moved the thread, no matter what I do, I just get a dialog with 'Invalid Security code' up when I send it.
There is of course no 'Captcha' or similar on the page, so nowhere to enter any code
18 Nov 2015 17:35 #65450 by jepler
jepler replied the topic: Option to move topic disappeared
apparently the captcha doesn't work properly when visiting the site using https. I will try to resolve this later today. Until then, you can try using a http:// url to access the forum and then send an e-mail.
18 Nov 2015 18:20 #65453 by jepler
I believe I have resolved this. the captcha displays for me now on chrome and firefox when accessing the forum using http and https. I also checked the new account page and it displays there, though I didn't complete any new account registrations as a check.
The following user(s) said Thank You: ArcEye
19 Nov 2015 06:54 - 19 Nov 2015 12:57 #65484 by ArcEye
Just tried it on a windows tablet running Firefox under https access and works now thanks.
Will try again from linux and iceweasel, but don't expect any problem.
EDIT: Tested with https:// on iceweasel and all working as it should be
Last Edit: 19 Nov 2015 12:57 by ArcEye.
Time to create page: 0.096 seconds
