axis select
- Thank you received: 2177
22 Sep 2023 04:06 #281355
axis select was created by Aciera
Try using
halui.axis.L.select bit in
pin for selecting axis by letter
22 Sep 2023 04:44 - 22 Sep 2023 04:45 #281359
Replied by Aciera on topic axis select
Could you attach your ini and hal files?
Last edit: 22 Sep 2023 04:45 by Aciera.
22 Sep 2023 08:21 #281373
in your hal file none of the halui.axis.L.select pins are connected to anything.
Example here for axis x, same for y,z,a,b :
net joint-select-x halui.axis.x.select
22 Sep 2023 09:06 #281379
which graphical interface are you using?
22 Sep 2023 09:19 - 22 Sep 2023 09:19 #281382
Yes in AXIS gui, halui.axis.L.select will not change the mark of the selected axis.
I'm not sure if there is another gui with axis selection as most seem to provide separate jog buttons for all active axes.
Last edit: 22 Sep 2023 09:19 by Aciera.
- phillc54
- Thank you received: 2100
25 Sep 2023 00:27 - 27 Sep 2023 19:28 #281577
by phillc54
Replied by phillc54 on topic axis select
This should work for the AXIS GUI. Copy the attached file to your config directory then edit the INI file, in the [DISPLAY] section add:This will change the axis selection on the 0 to 1 transition of any halui joint/axis select pin.
USER_COMMAND_FILE = axis_selection.pyAttachments:
Last edit: 27 Sep 2023 19:28 by phillc54. Reason: Change file for both python2 and python3
- phillc54
26 Sep 2023 23:47 - 27 Sep 2023 00:22 #281691
by phillc54
What version of LinuxCNC are you running?
I just tried 2.8 on Buster and that works fine. I have test on 2.8, 2.9 and master.
Are you running it as a USER_COMMAND_FILE for the AXIS GUI in your INI file?
Last edit: 27 Sep 2023 00:22 by phillc54.
- phillc54
27 Sep 2023 00:38 #281693
by phillc54
Can you run LinuxCNC in a terminal and screenshot the exact error.
- phillc54
27 Sep 2023 01:04 - 27 Sep 2023 19:33 #281697
by phillc54
Is it possible that axis_selection.py has got some DOS/Windows style line endings?
You could try a copy paste from here:
Edit: Code fixed here
Last edit: 27 Sep 2023 19:33 by phillc54.
- phillc54
27 Sep 2023 01:13 #281700
by phillc54
What Linux distribution are you using?
My testing has been on Debians Buster and Bookworm.
Time to create page: 0.233 seconds
