Latency Test not opening 10.04
29 May 2011 02:20 #10140
by centaur
Latency Test not opening 10.04 was created by centaur
Hi all - I am a noob to EMC2 & Ubuntu. Installed fresh from live CD (3 times). In the apps drop down CNC appears and in this list at the bottom is the latency test title. I click on it and nothing happens - no latency test app opens. Clicking on EMC works.
What to do?
What to do?
29 May 2011 09:20 #10148
by cncbasher
Replied by cncbasher on topic Re:Latency Test not opening 10.04
will the latency test work from stepconf
29 May 2011 10:14 #10149
by Rick G
Replied by Rick G on topic Re:Latency Test not opening 10.04
You can try the latency test from a terminal window ...
Just open up a terminal window and type in
latency-test
wiki.linuxcnc.org/emcinfo.pl?TweakingSoftwareStepGeneration
However I would download and try the 8.04 live CD first.
The 8.04 version seems to work better on some computers and the 10.04 seems to work better on other (newer?) computers.
Rick G
latency-test
Rick G
30 May 2011 14:57 #10186
by centaur
Replied by centaur on topic Re:Latency Test not opening 10.04
Thanks cncbasher and Rick G - I am not certain how to launch stepconf but I did try the 'latency-test' in terminal and received the following:
centaur@centaur-desktop:~$ latency-test
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Hope this is not too long for a post - does this help to solve the problem?
30 May 2011 15:42 #10187
Replied by PCW on topic Re:Latency Test not opening 10.04
Can you post the output from the dmesg command?
Sounds like the dreaded "No local APIC present or hardware disabled" problem
30 May 2011 22:07 #10197
by centaur
Hello Peter - I am new to Linux and I am assuming you want me to simply run the 'dmesg' command in the terminal window. I did this and it is 100 miles long - anyway, here it is and I have no idea what any of it means.
centaur@centaur-desktop:~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d0000 - 00000000000d4000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000030000000 (usable)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x30000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 020000000 mask FF0000000 write-back
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 base 0E0000000 mask FF8000000 write-combining
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000d0000 - 00000000000d4000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 0000000030000000 (usable)
[ 0.000000] modified: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] modified: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-0000000030000000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0030000000 page 2M
[ 0.000000] kernel direct mapping tables up to 30000000 @ 10000-14000
[ 0.000000] RAMDISK: 233b4000 - 2403f664
[ 0.000000] ACPI Error: A valid RSDP was not found (20090903/tbxfroot-219)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 768MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 30000000
[ 0.000000] low ram: 0 - 30000000
[ 0.000000] node 0 low ram: 00000000 - 30000000
[ 0.000000] node 0 bootmap 00010000 - 00016000
[ 0.000000] (8 early reservations) ==> bootmem [0000000000 - 0030000000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00233b4000 - 002403f664] RAMDISK ==> [00233b4000 - 002403f664]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4108] BRK ==> [00008b1000 - 00008b4108]
[ 0.000000] #7 [0000010000 - 0000016000] BOOTMAP ==> [0000010000 - 0000016000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x00030000
[ 0.000000] HighMem 0x00030000 -> 0x00030000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x00030000
[ 0.000000] On node 0 totalpages: 196495
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 191008 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] SFI: Simple Firmware Interface v0.7 simplefirmware.org
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 30000000 (gap: 30000000:cec00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194959
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=9a2735da-924b-4af1-a6c1-6bc4871292b1 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3931840 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 754024k/786432k available (4539k kernel code, 31636k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff7fe000 ( 239 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1100.268 MHz processor.
[ 0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 2200.53 BogoMIPS (lpj=4401072)
[ 0.004052] Security Framework initialized
[ 0.004113] AppArmor: AppArmor initialized
[ 0.004131] Mount-cache hash table entries: 512
[ 0.004421] Initializing cgroup subsys ns
[ 0.004431] Initializing cgroup subsys cpuacct
[ 0.004440] Initializing cgroup subsys memory
[ 0.004460] Initializing cgroup subsys devices
[ 0.004467] Initializing cgroup subsys freezer
[ 0.004472] Initializing cgroup subsys net_cls
[ 0.004512] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.004518] CPU: L2 Cache: 256K (64 bytes/line)
[ 0.004527] mce: CPU supports 4 MCE banks
[ 0.004567] Performance Events: AMD PMU driver.
[ 0.004585] ... version: 0
[ 0.004589] ... bit width: 48
[ 0.004593] ... generic registers: 4
[ 0.004598] ... value mask: 0000ffffffffffff
[ 0.004602] ... max period: 00007fffffffffff
[ 0.004606] ... fixed-purpose events: 0
[ 0.004610] ... event mask: 000000000000000f
[ 0.004619] Checking 'hlt' instruction... OK.
[ 0.021074] SMP alternatives: switching to UP code
[ 0.031823] Freeing SMP alternatives: 31k freed
[ 0.031889] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.031910] ftrace: allocating 21003 entries in 42 pages
[ 0.043269] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.043281] weird, boot CPU (#0) not listed by the BIOS.
[ 0.043285] SMP motherboard not detected.
[ 0.043291] Local APIC not detected. Using dummy APIC emulation.
[ 0.043295] SMP disabled
[ 0.043848] Brought up 1 CPUs
[ 0.043854] Total of 1 processors activated (2200.53 BogoMIPS).
[ 0.044071] CPU0 attaching NULL sched-domain.
[ 0.044462] devtmpfs: initialized
[ 0.045154] regulator: core version 0.5
[ 0.045276] NET: Registered protocol family 16
[ 0.045550] EISA bus registered
[ 0.047379] PCI: PCI BIOS revision 2.10 entry at 0xfdaf1, last bus=1
[ 0.047385] PCI: Using configuration type 1 for base access
[ 0.049420] bio: create slab <bio-0> at 0
[ 0.049549] ACPI: Interpreter disabled.
[ 0.049669] vgaarb: loaded
[ 0.049929] SCSI subsystem initialized
[ 0.050033] libata version 3.00 loaded.
[ 0.050200] usbcore: registered new interface driver usbfs
[ 0.050226] usbcore: registered new interface driver hub
[ 0.050290] usbcore: registered new device driver usb
[ 0.050540] PCI: Probing PCI hardware
[ 0.050548] PCI: Probing PCI hardware (bus 00)
[ 0.050625] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.050749] pci 0000:00:01.0: supports D1
[ 0.050800] pci 0000:00:0a.0: reg 10 io port: [0xec00-0xecff]
[ 0.050811] pci 0000:00:0a.0: reg 14 32bit mmio: [0xdfffff00-0xdfffffff]
[ 0.050840] pci 0000:00:0a.0: reg 30 32bit mmio pref: [0xdff80000-0xdffbffff]
[ 0.050863] pci 0000:00:0a.0: supports D2
[ 0.050869] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050877] pci 0000:00:0a.0: PME# disabled
[ 0.051028] pci 0000:00:11.1: reg 20 io port: [0xfc00-0xfc0f]
[ 0.051122] pci 0000:00:11.2: reg 20 io port: [0xe400-0xe41f]
[ 0.051208] pci 0000:00:11.3: reg 20 io port: [0xe800-0xe81f]
[ 0.051310] pci 0000:01:00.0: reg 10 32bit mmio: [0xde000000-0xdeffffff]
[ 0.051320] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xd8000000-0xdbffffff]
[ 0.051330] pci 0000:01:00.0: reg 18 32bit mmio pref: [0xddc80000-0xddcfffff]
[ 0.051352] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xdfee0000-0xdfefffff]
[ 0.051419] pci 0000:00:01.0: bridge 32bit mmio: [0xdde00000-0xdfefffff]
[ 0.051428] pci 0000:00:01.0: bridge 32bit mmio pref: [0xd5b00000-0xddcfffff]
[ 0.051747] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.051871] pci 0000:00:11.0: VIA IRQ router [1106:3147]
[ 0.051898] pci 0000:00:11.1: hardcoded PCI INT A -> IRQ 14
[ 0.052205] NetLabel: Initializing
[ 0.052210] NetLabel: domain hash size = 128
[ 0.052213] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.052246] NetLabel: unlabeled traffic allowed by default
[ 0.052328] Switching to clocksource tsc
[ 0.056517] AppArmor: AppArmor Filesystem Enabled
[ 0.056530] pnp: PnP ACPI: disabled
[ 0.056539] PnPBIOS: Scanning system for PnP BIOS support...
[ 0.056611] PnPBIOS: Found PnP BIOS installation structure at 0xc00f78f0
[ 0.056618] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x67db, dseg 0xf0000
[ 0.057453] PnPBIOS: 14 nodes reported by PnP BIOS; 14 recorded by driver
[ 0.057479] system 00:01: iomem range 0x0-0x9fbff could not be reserved
[ 0.057487] system 00:01: iomem range 0x9fc00-0x9ffff could not be reserved
[ 0.057495] system 00:01: iomem range 0xf0000-0xfffff could not be reserved
[ 0.057502] system 00:01: iomem range 0x100000-0x2fffffff could not be reserved
[ 0.057509] system 00:01: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.057515] system 00:01: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.057522] system 00:01: iomem range 0xfff80000-0xffffffff has been reserved
[ 0.057913] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.057918] pci 0000:00:01.0: IO window: disabled
[ 0.057928] pci 0000:00:01.0: MEM window: 0xdde00000-0xdfefffff
[ 0.057936] pci 0000:00:01.0: PREFETCH window: 0xd5b00000-0xddcfffff
[ 0.057963] pci 0000:00:01.0: setting latency timer to 64
[ 0.057973] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.057979] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.057985] pci_bus 0000:01: resource 1 mem: [0xdde00000-0xdfefffff]
[ 0.057991] pci_bus 0000:01: resource 2 pref mem [0xd5b00000-0xddcfffff]
[ 0.058070] NET: Registered protocol family 2
[ 0.058267] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.059084] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.062152] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.063754] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.063761] TCP reno registered
[ 0.063994] NET: Registered protocol family 1
[ 0.064035] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.064095] pci 0000:01:00.0: Boot video device
[ 0.064571] Scanning for low memory corruption every 60 seconds
[ 0.064777] audit: initializing netlink socket (disabled)
[ 0.064803] type=2000 audit(1306792774.063:1): initialized
[ 0.080092] Trying to unpack rootfs image as initramfs...
[ 0.096027] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.102987] VFS: Disk quotas dquot_6.5.2
[ 0.103129] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.104464] fuse init (API version 7.13)
[ 0.104648] msgmni has been set to 1473
[ 0.112115] alg: No test for stdrng (krng)
[ 0.112322] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.112330] io scheduler noop registered
[ 0.112336] io scheduler anticipatory registered
[ 0.112340] io scheduler deadline registered
[ 0.112439] io scheduler cfq registered (default)
[ 0.112667] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.112718] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.116132] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.116306] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.116434] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.116930] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.117124] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.119656] isapnp: Scanning for PnP cards...
[ 0.127722] brd: module loaded
[ 0.128960] loop: module loaded
[ 0.129213] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.129582] pata_acpi 0000:00:11.1: hardcoded PCI INT A -> IRQ 14
[ 0.129618] pata_acpi 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 14
[ 0.130489] Fixed MDIO Bus: probed
[ 0.130572] PPP generic driver version 2.4.2
[ 0.130678] tun: Universal TUN/TAP device driver, 1.6
[ 0.130683] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.130879] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.130916] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.130943] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.131014] PCI: setting IRQ 9 as level-triggered
[ 0.131022] uhci_hcd 0000:00:11.2: found PCI INT D -> IRQ 9
[ 0.131044] uhci_hcd 0000:00:11.2: sharing IRQ 9 with 0000:00:11.3
[ 0.131063] uhci_hcd 0000:00:11.2: UHCI Host Controller
[ 0.131149] uhci_hcd 0000:00:11.2: new USB bus registered, assigned bus number 1
[ 0.131194] uhci_hcd 0000:00:11.2: irq 9, io base 0x0000e400
[ 0.131453] usb usb1: configuration #1 chosen from 1 choice
[ 0.179194] hub 1-0:1.0: USB hub found
[ 0.179246] hub 1-0:1.0: 2 ports detected
[ 0.179409] uhci_hcd 0000:00:11.3: found PCI INT D -> IRQ 9
[ 0.179435] uhci_hcd 0000:00:11.3: sharing IRQ 9 with 0000:00:11.2
[ 0.179460] uhci_hcd 0000:00:11.3: UHCI Host Controller
[ 0.179659] uhci_hcd 0000:00:11.3: new USB bus registered, assigned bus number 2
[ 0.179703] uhci_hcd 0000:00:11.3: irq 9, io base 0x0000e800
[ 0.179958] usb usb2: configuration #1 chosen from 1 choice
[ 0.180043] hub 2-0:1.0: USB hub found
[ 0.180066] hub 2-0:1.0: 2 ports detected
[ 0.180275] PNP: PS/2 Controller [PNP0303,PNP0f13] at 0x60,0x64 irq 1,12
[ 0.184053] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.184083] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.184512] mice: PS/2 mouse device common for all mice
[ 0.184778] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.184813] rtc0: alarms up to one day, 114 bytes nvram
[ 0.185037] device-mapper: uevent: version 1.0.3
[ 0.185323] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.188100] device-mapper: multipath: version 1.1.0 loaded
[ 0.188112] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.188534] EISA: Probing bus 0 at eisa.0
[ 0.188586] EISA: Detected 0 cards.
[ 0.188592] cpuidle: using governor ladder
[ 0.188598] cpuidle: using governor menu
[ 0.189441] TCP cubic registered
[ 0.189786] NET: Registered protocol family 10
[ 0.190634] lo: Disabled Privacy Extensions
[ 0.191222] NET: Registered protocol family 17
[ 0.191301] Using IPI No-Shortcut mode
[ 0.194994] registered taskstats version 1
[ 0.195354] rtc_cmos 00:05: setting system clock to 2011-05-30 21:59:34 UTC (1306792774)
[ 0.195363] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.195367] EDD information not available.
[ 0.208902] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.795085] isapnp: No Plug & Play device found
[ 1.170123] Freeing initrd memory: 12845k freed
[ 1.202925] Freeing unused kernel memory: 620k freed
[ 1.204654] Write protecting the kernel text: 4540k
[ 1.204703] Write protecting the kernel read-only data: 1668k
[ 1.263922] udev: starting version 151
[ 1.501079] dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
[ 1.501168] PCI: setting IRQ 10 as level-triggered
[ 1.501177] dmfe 0000:00:0a.0: found PCI INT A -> IRQ 10
[ 1.576352] Linux agpgart interface v0.103
[ 1.584118] eth0: Davicom DM9102 at pci0000:00:0a.0, 00:08:a1:1e:c9:0f, irq 10.
[ 1.584174] pata_via 0000:00:11.1: version 0.3.4
[ 1.584196] pata_via 0000:00:11.1: hardcoded PCI INT A -> IRQ 14
[ 1.584228] pata_via 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 14
[ 1.585630] scsi0 : pata_via
[ 1.586090] scsi1 : pata_via
[ 1.586176] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 1.586184] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 1.586459] agpgart: Detected VIA KT266/KY266x/KT333 chipset
[ 1.598903] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xe0000000
[ 1.723957] [drm] Initialized drm 1.1.0 20060810
[ 1.767672] ata1.00: ATA-3: FUJITSU MPC3043AT, 6801, max UDMA/33
[ 1.767679] ata1.00: 8448300 sectors, multi 16: LBA
[ 1.783558] ata1.00: configured for UDMA/33
[ 1.807550] ata1.00: configured for UDMA/33
[ 1.807558] ata1: EH complete
[ 1.807852] scsi 0:0:0:0: Direct-Access ATA FUJITSU MPC3043A 6801 PQ: 0 ANSI: 5
[ 1.808258] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.809044] sd 0:0:0:0: [sda] 8448300 512-byte logical blocks: (4.32 GB/4.02 GiB)
[ 1.809175] sd 0:0:0:0: [sda] Write Protect is off
[ 1.809182] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.809249] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1.809605] sda: sda1 sda2 < sda5 >
[ 1.851600] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.987663] ata2.00: ATAPI: CR-48X9TE, 1.0B, max UDMA/33
[ 2.019526] ata2.00: configured for UDMA/33
[ 2.024676] scsi 1:0:0:0: CD-ROM MITSUMI CR-48X9TE 1.0B PQ: 0 ANSI: 5
[ 2.032323] sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 2.032334] Uniform CD-ROM driver Revision: 3.20
[ 2.032988] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.033283] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.143058] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x017200a3)
[ 2.143389] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 2.274656] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.275075] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 2.275082] [drm] nouveau 0000:01:00.0: BMP version 5.20
[ 2.275089] [drm] nouveau 0000:01:00.0: Bios version 04.17.00.37
[ 2.275096] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 2.0
[ 2.275106] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 01000100 000088b8
[ 2.275114] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 02010210 000088b8
[ 2.275120] [drm] nouveau 0000:01:00.0: Raw DCB entry 2: 02010111 00000033
[ 2.275126] [drm] nouveau 0000:01:00.0: Raw DCB entry 3: 02010311 00000003
[ 2.275131] [drm] nouveau 0000:01:00.0: Merging DCB entries 2 and 3
[ 2.275490] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode
[ 2.275499] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xC30A
[ 2.275549] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xC63B
[ 2.283232] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xC40A
[ 2.283280] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xCB43
[ 2.283293] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xC597
[ 2.299556] [TTM] Zone kernel: Available graphics memory: 383922 kiB.
[ 2.299587] [drm] nouveau 0000:01:00.0: 64 MiB VRAM
[ 2.299691] agpgart-via 0000:00:00.0: AGP 2.0 bridge
[ 2.299721] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.299769] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.299777] [drm] nouveau 0000:01:00.0: 128 MiB GART (aperture)
[ 2.300167] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 2.302166] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.302191] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[ 2.302201] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.342334] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.342751] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.342937] [drm] nouveau 0000:01:00.0: Detected a TV connector
[ 2.344296] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.344304] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 1)
[ 2.344311] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 2)
[ 2.619163] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 2.619471] [drm] nouveau 0000:01:00.0: allocated 1024x768 fb: 0x49000, bo e3b0fa00
[ 2.619887] fb0: nouveaufb frame buffer device
[ 2.619893] registered panic notifier
[ 2.619907] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.626764] vga16fb: initializing
[ 2.626780] vga16fb: mapped to 0xc00a0000
[ 2.626793] vga16fb: not registering due to another framebuffer present
[ 2.664066] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 2.664080] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output A
[ 2.683326] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on TV encoder (output 2)
[ 2.683342] [drm] nouveau 0000:01:00.0: Output TV-1 is running on CRTC 1 using output B
[ 2.684488] Console: switching to colour frame buffer device 90x36
[ 3.364717] xor: automatically using best checksumming function: pIII_sse
[ 3.383038] pIII_sse : 2998.000 MB/sec
[ 3.383044] xor: using function: pIII_sse (2998.000 MB/sec)
[ 3.390384] device-mapper: dm-raid45: initialized v0.2594b
[ 3.778055] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 26.575381] udev: starting version 151
[ 26.639980] Adding 240632k swap on /dev/sda5. Priority:-1 extents:1 across:240632k
[ 26.812625] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 26.835243] lp: driver loaded but no devices found
[ 27.355070] irda_init()
[ 27.355119] NET: Registered protocol family 23
[ 27.450250] type=1505 audit(1306792801.752:2): operation="profile_load" pid=383 name="/sbin/dhclient3"
[ 27.468078] type=1505 audit(1306792801.772:3): operation="profile_load" pid=383 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 27.468855] type=1505 audit(1306792801.772:4): operation="profile_load" pid=383 name="/usr/lib/connman/scripts/dhclient-script"
[ 27.572874] psmouse serio1: ID: 10 00 64
[ 27.634480] logips2pp: Detected unknown logitech mouse model 74
[ 28.154674] input: PS/2 Logitech Mouse as /devices/platform/i8042/serio1/input/input2
[ 28.355690] type=1505 audit(1306792802.659:5): operation="profile_load" pid=537 name="/usr/share/gdm/guest-session/Xsession"
[ 28.370824] type=1505 audit(1306792802.671:6): operation="profile_replace" pid=539 name="/sbin/dhclient3"
[ 28.407776] type=1505 audit(1306792802.711:7): operation="profile_replace" pid=539 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 28.408194] type=1505 audit(1306792802.711:8): operation="profile_replace" pid=539 name="/usr/lib/connman/scripts/dhclient-script"
[ 28.551757] type=1505 audit(1306792802.855:9): operation="profile_load" pid=542 name="/usr/bin/evince"
[ 28.557285] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 28.602672] type=1505 audit(1306792802.903:10): operation="profile_load" pid=542 name="/usr/bin/evince-previewer"
[ 28.647754] type=1505 audit(1306792802.951:11): operation="profile_load" pid=542 name="/usr/bin/evince-thumbnailer"
[ 29.411265] ppdev: user-space parallel port driver
[ 29.687236] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 30.147086] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 30.157474] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 30.176101] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 30.612463] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 2)
[ 30.641055] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on TV encoder (output 2)
[ 30.641066] [drm] nouveau 0000:01:00.0: Output TV-1 is running on CRTC 1 using output B
[ 32.318677] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 32.802604] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 33.302528] [drm] nouveau 0000:01:00.0: Load detected on output B
[ 40.625493] [drm] nouveau 0000:01:00.0: Load detected on output B
30 May 2011 22:29 #10199
by BigJohnT
Replied by BigJohnT on topic Re:Latency Test not opening 10.04
I see from your computer name it is a 6 core? RTAI is known to have problems with more than a few cores...
wiki.linuxcnc.org/emcinfo.pl?The_Isolcpu..._Parameter_And_GRUB2
30 May 2011 22:39 #10200
Also this:
may need some grub/BIOs setup tweaking as well
31 May 2011 00:10 #10203
by centaur
Hi BJT and PCW - I see your names a lot on this forum and you are definitely an asset.
BJT - the mobo is actually an older unit from my pile of stuff. It is an MSI K7T266 Pro2-A and is in the DDR ram erra. The CPU is a vanilla single core 1.0ghz AMD Athlon. I chose this mobo because it has a PP and EPP selectable in the BIOS.
PCW - I looked in CMOS and sure enough the APIC was in the disabled setting. I enabled it and rebooted - voila! I have latency test now. BUT - now I suddenly have no USB when I plug in my flash. (I mentioned this in post elsewhere in this forum)
Now to shift focus for a moment - the jitter I am seeing is quite high - 84,144 on the servo thread. I just purchased a 7i43 with a 7i33 and I am wondering if this mobo is not going to perform for what I will need. It would be nice to have my USB back but if the mobo is not going to do the job there may be no point in the pursuit of this issue.
I'm getting the feeling that I'm in over my head.
31 May 2011 01:14 #10205
No idea what the USB problem is from, but anyway...
84 uSec latency is probably OK for a servo system, and your latency figures
may be improved if you look at the wiki suggestions for improving latency.
As others have suggested, you might try the Ubuntu 8.04 release as it often
does better on older motherboards.
Time to create page: 0.214 seconds
