Small Footprint linux
I have used Suse before but it is just way to heavy
Cheers
Damo
- step4linux
- Thank you received: 5
The simplest way to run EMC is using ubuntu. The smallest ubuntu is probably xubuntu.
I run EMC 2.3.4-1 with xubuntu 8.04 on a probably 5 years old dell laptop, 1 GHz, 256 MB, 10 GB disk.
Its not exciting, but its ok.
Latency is ok after switching off SMI.
rgds Gerd
Cheers
Damo
step4linux wrote:
what is small, what is old ?
rgds Gerd
- step4linux
- step4linux
You mean if it runs better with xubuntu, versus standard ubuntu ?Will EMC2 run better if I use xbuntu O/S on a older single core Atom mobo (D945GCLF)?
well, in terms of latency, there is no difference. This means the performance of your machine is the same.
If your board has less than 0.5 G memory, you probably will have a better feeling of fluent interaction with you computer.
rgds Gerd
Thank you for you attention, appreciate your answer.
You understand my question concisely.
I'm not very well verse with these stuff so I beef up 2 Gb ram onboard, I recon with this size ram, the EMC would not complain about sharing memory with graphics or anything else and the mobo is a EMC2 dedicated, no LAN, no wireless, noprinter, no HDD, just thumbdrive, monitor, keyboard & a mouse.... bare minimum.
"Fluent interaction" with the computer will be a great reason to have a go at Xubuntu, its nice to have especially when under pressure to do things on the fly.
Will try this Xubuntu out once I can find time for it.
Ken
- step4linux
