UBUNTU 8.04
26 Jan 2010 17:13 #1639 by OLD BOB
UBUNTU 8.04 was created by OLD BOB
I have a computer I want to install only UBUNTU 8.04 as the only O/S.
Can I use the live -CD to do that or is there a better way?
27 Jan 2010 00:11 #1640 by BigJohnT
Replied by BigJohnT on topic Re:UBUNTU 8.04
The LiveCD is the best way as you get EMC installed all at once. Just remember to connect to the internet and get the updates to EMC and do not update the OS if asked.
30 Jan 2010 15:24 #1698 by OLD BOB
Replied by OLD BOB on topic Re:UBUNTU 8.04
I have doenloaded and burned the live CD twice and still have the same results.
I am using an INTEL ATOM mini ITX mother board. I have a USB CD/DVD ROM DRIVE BURNER. The case does not have room fo a optical drive.
So I run the live cd and install the program through windows.
I guess to day I will try a different older computer.
Bob
31 Jan 2010 11:07 #1708 by Rick G
Replied by Rick G on topic Re:UBUNTU 8.04
Not sure what problem you are having loading EMC/UBUNTU, but I recently helped a friend load them with the live CD on a ATOM board and had to go into the BIOS and turn off the LAN before they would load.
Rick
31 Jan 2010 13:10 #1710 by OLD BOB
I read some where that the ATOM has a bug and will not run UBUNTU 8.04 right.
I gave up on the ATOM computer and went with an old CELRON1.2 Ghz which seems to be working OK
But now I am trying to get email and the printer working.
BOB
Time to create page: 0.065 seconds
