Need some help with Ubuntu and parallel ports
- garymcrobertpdx
01 Feb 2010 18:05 #1725
by garymcrobertpdx
Need some help with Ubuntu and parallel ports was created by garymcrobertpdx
Need some help with Ubuntu. Used the EMC2 setup
Wizard the primary Parallel port at 0x378 works fine
but the second PCI card par port at 0x278 fails to work.
I have studied the ENC2 integrators manual and the help
info for Ubuntu OS and tried many things but no luck.
I have not even been able to discover if the OS has even
detected the card.
Can some one give me a quick tutorial or point me to
detailed information on how to deal with installing a
parallel port into the Ubuntu OS.
detected the card.
01 Feb 2010 20:20 #1726
by acemi
Replied by acemi on topic Re:Need some help with Ubuntu and parallel ports
The PCI parallel card usually don't use 0x278. Use "lspci -v" command to find the address.
For more info:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?NetMos
For more info:
Time to create page: 0.080 seconds
