DXF Converter
- atakan.karatas
03 Feb 2010 08:50 #1731
by atakan.karatas
DXF Converter was created by atakan.karatas
Hi!
We use EMC2 CNC Controller. We have some problem about converter.
We made project with Corell Draw and AutoCad file DXF Format but some projects don't open with gcode converter. How could be solve that problem.
And we couldn't open 3d project with EMC2 Software.
Please help me...
Tahanks,
Atakan KARATAS
Please help me...
Tahanks,
Atakan KARATAS
03 Feb 2010 10:31 #1732
by Rick G
Replied by Rick G on topic Re:DXF Converter
Hello,
If you start with a dxf file you need to convert it to a g code file for EMC to run it. What converter are you using?
Rick G
Rick G
- atakan.karatas
03 Feb 2010 10:40 #1733
by atakan.karatas
Replied by atakan.karatas on topic Re:DXF Converter
Thaks Rick.
Our problems are that projects already open together with Deskcnc but we don't open our converter program..
- atakan.karatas
03 Feb 2010 10:53 #1734
by atakan.karatas
Hi rick are you there??
03 Feb 2010 11:01 #1735
by acemi
Replied by acemi on topic Re:DXF Converter
What do you mean with "the converter program"?
Do you try to open dxf files from Axis?
- atakan.karatas
03 Feb 2010 11:06 #1736
by atakan.karatas
Hi! I mean there are a project by Autocat or Corell Draw ve Save dxf and use g code converter but our g converter program some times open this projects but a few project don't open, Already deskcnc program open direct dxf file
03 Feb 2010 12:03 #1737
by Rick G
Not sure what converter program you are using and I have no experience with Deskcnc.
However for everything to work you need to take your Corel drawing and save it in a version of dxf that your converter program understands.
From there your converter needs to create the g code file in a version that EMC understands. (post processors) You may find more info in the G code section of this forum.
Rick G
Rick G
Time to create page: 0.107 seconds
