Renishaw Linear Encoders, EMC2 and Mesa 5120
05 Feb 2010 00:29 #1752
by Hobbydad
Renishaw Linear Encoders, EMC2 and Mesa 5120 was created by Hobbydad
Hello!
I am wanting to use Renishaw Linear Encoders with a Mesa 5120 controller card, is this possible and does EMC2 support linear encoders. Also does EMC2 and Mesa 5120 support switches(out of range) for x,y & z incase the machine just takes off?
Thanks,
Hobbydad
Thanks,
Hobbydad
05 Feb 2010 01:53 #1754
Replied by cmorley on topic Re:Renishaw Linear Encoders, EMC2 and Mesa 5120
Short answer : yes yes and yes
I assume the encoders output square wave signals. Mesa can count them
You can use linear scales with EMC . Whether thats a good idea depends what you are doing.
Steppers? servos? Only using linear scales with servos might not work that well , better is to use rotary encoder on the motor or ball screws and
optionally linear scales on the slides. The problem with just using linear scales is the EMC can't tell when the motor is moving when there is backlash
and thats screws with the tuning.
With steppers EMC can use the scales to monitor if a real following error has happenned.
see here:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Steppers_With_Encoders
EMC supports real limit switches and software limits. If using servos with PID control you can also have EMC monitor the output of the PID and if it saturates (at maximum output) for too long throws an Estop.
see here:
05 Feb 2010 02:09 #1755
by Hobbydad
Replied by Hobbydad on topic Re:Renishaw Linear Encoders, EMC2 and Mesa 5120
Yes encoders are square wave! I am using slides for the xyz travel. As far as I know these are servos, the reason I guess was the machine I'm converting over was very precise with it's movement down to microns. I haven't tore into the drives or evn where they are at but they would seem small in size.
Any suggestions on steppers if I wanted to change it over?
Thanks,
Hobbydad
Thanks,
Hobbydad
05 Feb 2010 02:53 #1757
Replied by PCW on topic Re:Renishaw Linear Encoders, EMC2 and Mesa 5120
If you have low backlash you may get away with using the linear encoders without any rotary encoders on the motor
We have had customers this setup that were able to get good performance. Having velocity mode amplifiers will help.
If the existing motors and drives work changing to step motors would be a _step_ down...
08 Feb 2010 00:53 #1808
by Hobbydad
Good that's what I wanted to hear that it would proubably work ok. The amps are Allen Bradley and they do support different modes.
Cmorley,
I downloaded GCAM but I can't find it on my computer anywhere. When I try to reinstall it says that it is there. Now granted i'm not 100% of a linux user yet and maybe i'm overlooking where it is at. I am using Ubuntu 8.04 Hardy Heron rel. April 2008. maybe there is a version conflict don't know!
Thanks,
Hobbydad
Cmorley,
Thanks,
Hobbydad
Time to create page: 0.275 seconds
