downloading EMC2.2 ISO
17 Feb 2010 15:24 #1946
by graflex
downloading EMC2.2 ISO was created by graflex
I have had a copy of EMC2 for around 4 years which boots upon PC's with no hard drive installed. I tried the same disc on a Dell Laptop and found it hangs at line 510 SQUASHFS Ver 3. Downloading a new copy of EMC 2.2. and following the instructions to download and burn to CD I get a copy that will not boot. Is there a difference in the later versions?
23 Feb 2010 00:12 #2006
by greeder88
Replied by greeder88 on topic Re:downloading EMC2.2 ISO
My experiences may or may not help your situation but I found it extremely difficult to get a good cd burned that would boot. I checked my downloaded file with checksum and it matched but the trouble was with the burning process.
What worked for me was to download INFRARECORDER and also to use it a certain way.
1. Download and install Infra Recorder, a free and open source image burning program.
2. Insert a blank CD in the drive and select Do nothing or Cancel if an auto-run dialog pops up.
3. Open Infra Recorder, and select the 'Actions' menu, then 'Burn image'.
Follow these steps and should have a good bootable CD.
Time to create page: 0.061 seconds
