[Solved] Parallel Port in Stepconf wizard
25 Feb 2010 11:32 - 02 Mar 2010 23:21 #2058
by cncjohn
[Solved] Parallel Port in Stepconf wizard was created by cncjohn
Hi all, I am another newbie to cnc and am very excited about this community and the stuff cnc can do. I just took delivery of this model of a chinese 4 Axis TB6560 CNC Stepper Motor Driver Board. Well after a 3 week delay due to customs in lisbon! Had to pay import tax before they would release it.
The board is up and running but I cannot decipher the chinglish manual. I want to know what they mean by X enable Y enable and Z enable in the the parallel port setup step.
I use Ubuntu Live 8-04 and EMC2 and these choices dont exist in the Stepconf wizard of EMC2.
The definition of 1-PIN 25 of Parallel Interface in the English user manual document says:
PIN2 Spindle motor
PIN4 X Enable ????
PIN1 X Dir
PIN16 X Step
PIN17 Y Enable ????
PIN7 Y Dir
PIN14 Y Step
PIN5 Z Enable ????
PIN6 Z Dir
PIN3 Z Step
I tried using the Step and the Direction options in place of Enable - ticking and unticking the invert box. Limited success so far - Im sure something isnt right.
Any help would be welcome. Also Im thinking of using a 24 v 10 a power supply but I dont seem able to find one under 300 euros. Ideas please...
Regards John
Cmorley knew about this one - all to be marked as amplifier enable. +1 karma cheers fella
PIN2 Spindle motor
PIN4 X Enable ????
PIN1 X Dir
PIN16 X Step
PIN17 Y Enable ????
PIN7 Y Dir
PIN14 Y Step
PIN5 Z Enable ????
PIN6 Z Dir
PIN3 Z Step
Regards John
Last edit: 02 Mar 2010 23:21 by cncjohn. Reason: Solved
26 Feb 2010 04:49 #2067
Replied by cmorley on topic Re:Parallel Port in Stepconf wizard
In stepconf the the signal name you are looking for is 'Amplifier Enable'
You can have multiple pins with this signal if you like.
Chris M
Chris M
- step4linux
- Thank you received: 5
26 Feb 2010 11:48 #2075
by step4linux
Replied by step4linux on topic Re:Parallel Port in Stepconf wizard
cncjohn wrote:
Do you really need 10 Amp ? For 5 Amps, there are nice lo cost laptop switching pwr sup with 24V/5Amp. at ebay. Could be even with 7.5 Amp, not sure.
rgds Gerd
Regards John
rgds Gerd
26 Feb 2010 21:17 #2079
by cncjohn
Replied by cncjohn on topic Re:Parallel Port in Stepconf wizard
Cmorley you're a godsend. Thanks to you it seems to work now. Don't worry I will think of more questions lol.
26 Feb 2010 21:19 #2080
by cncjohn
step4linux wrote:
Thanks step4linux I think I should try one. I will let you know how I get on. cncjohn
Regards John
rgds Gerd
Time to create page: 0.083 seconds
