Soft Limit
19 Mar 2010 18:40 #2376
by cncjohn
Soft Limit was created by cncjohn
Hello All, I hope someone can solve this problem it's confusing to a newbie like me.
I have no problem using EMC2 generally - all working as expected but today I used a tool to trace truetype fonts and convert it to gcode. The file it produced seemed okay and made it to line 1046 before this error popped up:
"exceeded soft limit. cant do that. (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter idle.)
The line 1046 reads G01 X[8512.00*#3+#5] Y[1003*#3+#6]
this works out to G01 X98.096 Y58.024
My X travel is 0 to 850mm and Y 0 to 230mm
Any ideas anyone or maybe suggest some pointers as to where to look i.e. which .ini files relate to this setting. Thanks ... John:blink:
20 Mar 2010 10:44 #2383
by acemi
Replied by acemi on topic Re:Soft Limit
Maybe your machine coordinates are not the same with your actual coordinates.
Or the soft limits are not set correctly in your INI file.
Or the limits are metric but the program uses inches
23 Mar 2010 17:04 #2425
by cncjohn
Replied by cncjohn on topic Re:Soft Limit
Scaling the drawing down seemed to overcome this problem. I will take your advice and check the stuff you said. Do you think it may be related to a post I recently saw that mentioned inserting a line n the ini file in the traj section NO_FORCE_HOMING=0?
Time to create page: 0.059 seconds
