EMC 2 setup
31 Mar 2010 13:02 #2485 by forSaleSticker
EMC 2 setup was created by forSaleSticker
Hi -
I am new to EMC and need just a little help to get off the ground.
When I load EMC (stepper-gantry) everything looks fine but I can not toggle or turn off the eStop / emergency stop.
Do I need to be connected to the CNC machine before I can turn this off? (I just wanted to do a test run)
Or is something else broken in my configuration?
31 Mar 2010 20:47 #2486 by eslavko
Replied by eslavko on topic Re:EMC 2 setup
Probably you have missconfigured EStop switch.
31 Mar 2010 21:13 #2487 by forSaleSticker
Replied by forSaleSticker on topic Re:EMC 2 setup
So do I have to have the parallel cable connected to untoggle estop?
If I am using the computer in my office (not connected to my CNC) can I turn the estop off?
How do I configure that?
31 Mar 2010 21:33 #2489 by eslavko
If you have external EStop then you can't use software EStop for same manner. ..but you can still use both. Just look for EStop component. And stepconf can't do that. You must manualy edit Hal file.
01 Apr 2010 11:16 #2490 by BigJohnT
Replied by BigJohnT on topic Re:EMC 2 setup
That config states in the description that it is configured for an external hardware E-Stop. Try another config like Axis Sim.
Time to create page: 0.127 seconds
