Noob 1st Post - EMC and Pneumatic Roboarm
04 Apr 2010 12:22 - 04 Apr 2010 15:34 #2505 by GMTG
OK this is my first post here so go easy on me :unsure:
My buddy and I are starting to mess around with the software and trying to retrofit a couple old crappy machines i have
with our first project being an old parker schrader bellows motion mate pneumatic cylinder powered robot arm
He set up a breadboard to accept the outputs of the parallel port and got a row of leds to light from the step/dir signals
from the axis2 engraving example which loads with emc2
The robot arm is old school pneumatic cylinders for all axes - sort of a pick and place deal
with 120 volt solenoids on a manifold block - a row of 5v - 120v optoisolator relays will supply power to the noids
The control that came with it is pretty much shot - powers up but all light stay on and nothing happens lol
What im trying to figure out is how in gcode would i best go about programming actions for the arm? - user defined codes?
If anyone can give me some insight it would be much appreciated.
I will update this thread as i move along - maybe with some pics in a couple days or something
Last edit: 04 Apr 2010 15:34 by GMTG.
04 Apr 2010 15:25 #2507 by GMTG
screenshot of manual i got parker to send me over net
04 Apr 2010 21:11 #2511 by GMTG
hallllp :silly:
this is me and the robot
04 Apr 2010 21:15 - 04 Apr 2010 21:16 #2512 by GMTG
this is my dad and the robot
Last edit: 04 Apr 2010 21:16 by GMTG.
07 Apr 2010 22:17 #2537 by GMTG
im just looking for some direction
why aren't there any responses?
someone could at least tell me to bug off or something :(
07 Apr 2010 22:32 #2539 by Rick G
GMTG,
It looks like a interesting project, but I have no experience with such a device. How are moves made? Are there encoders for feed back? Once the geometry is set up g codes will probably work fine. I think the group just needs more info to help. That said it would be cool to see it work!
Rick G
07 Apr 2010 23:16 #2540 by GMTG
Rick G wrote:
GMTG,
Rick G
hello sir
thank you for replying
ive been biting my nails and pulling my hair out trying to figure out why noone was talking to me lol
im going to attempt to attach the files parker shrader bellows sent me
which should explain its original operation
the control box and pendant which normally would control it are pretty much shot
it powers on but all the lights on the front panel come on and stay on
......and nothing happens B)
there are mechanical stops and magnetic limit switches
the control is some kind of simple computer
that shoots 120volts out to each solenoid to fire the pneumatic cylinder
so we figured we could eliminate the old one and just use a pc
and were originally going to try and write some kind of visual basic type deal
to recreate the pendant and its functions
but came across emc and figured it would be worth a shot
i paid 20 bucks for the thing at hgr
which would explain why the control is all jacked up
again im just looking for someone to shove me in the right direction
08 Apr 2010 01:22 - 08 Apr 2010 12:02 #2541 by GMTG
double tap sorry
Last edit: 08 Apr 2010 12:02 by GMTG.
08 Apr 2010 11:06 - 08 Apr 2010 11:10 #2542 by BigJohnT
What kind of feedback for position does it have?
It will be interesting to be sure with a strange beast like that. Also, there is not much traffic on the forum so sometimes it takes a while for someone to respond.
For switching 120vac with your computer you will need some kind of relay board to do that.
Last edit: 08 Apr 2010 11:10 by BigJohnT.
08 Apr 2010 11:11 #2543 by Rick G
O.K.
How many solenoids are there and what do they do? You can use EMC to turn a parallel port pin on and off. You can then amplify this 5 volt signal to activate a relay to turn the solenoid on and off. Typical use for spindle, coolant, mist on and off. You can also use EMC to read the output of the limit switches. You may be able to use John Thorton's popular Simple Remote Pendant to control it ,also if you need more options look at Adding more controls to the simple remote pendant.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Simple_Remote_Pendant
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Add...imple_Remote_Pendant
Rick G
Time to create page: 0.136 seconds
