Noob 1st Post - EMC and Pneumatic Roboarm
08 Apr 2010 11:13 #2544 by Rick G
John typed faster than me.
08 Apr 2010 11:20 #2546 by BigJohnT
And I overslept this morning LOL.
09 Apr 2010 03:22 #2547 by GMTG
i thought i attached the pdf to the last reply
but maybe not
25 Apr 2010 15:50 #2695 by GMTG
hello again
my buddy and i successfully fired a couple of the solenoids the other day on the robot arm
running the emc2 axis preloaded program
outputting the raw step dir signals
so the solenoids and cylinders were pretty much just firing erratically
how are solenoids programmed in gcode by others?
anyone have any examples?
25 Apr 2010 17:52 #2696 by BigJohnT
25 Apr 2010 22:10 #2705 by GMTG
duly noted sir
maybe ill just post more screenshots of the manual if i need to
my buddy was over again today and we sort of formulated a plan
on what to reuse from the old control and how to go about wiring everything up
im still wondering about how to control the solenoids from gcode
we were thinking - 10 solenoids - 10 pins --- 5 positive direction signals and 5 negative
each axis named and assigned a positive and negative direction signal
the robot arm has 6 limit switches that are normally open and carry 115 vac
but were not totally sure we need to even use them
as all stops and distances traveled by the cylinders are mechanical in nature
im just thinking out loud here hoping someone will chime in with some comment
that will help me bridge the disconnect in my brain lol
here is a picture of a borrowed 1/2 ton chevy with a 2500 lb Wells Index 823 mill torn apart and overloaded into the bed
this will be next to be retrofitted after the robotarm
25 Apr 2010 22:18 #2706 by BigJohnT
Well you don't have to call me sir...
When you energize a solenoid what happens? Does it just go to full travel or is there some kind of position feedback and rod lock to stop a some position?
25 Apr 2010 22:37 #2708 by GMTG
yes when solenoid energized it just goes to full travel where it meets adjustable mechanical stops and limit switches will close
but limit switches only postion feedback --- on grip for example there is no limit switch
i was thinking of setting up axes so they only had two positions - o and 1
- like arm forward/retract is x and only positions possible are X0 and X1 but x is comprised of 2 cylinders - 1 forward and 1 rertact etc
but im not really sure how this would translate into Gcode as i have about zero experience with it
but ive been reading the emc manuals lol
25 Apr 2010 22:39 #2709 by GMTG
and sorry for calling you sir lol
just being respectful
heres another pic of the bot
25 Apr 2010 22:51 #2711 by GMTG
when we put air to the thing when we had the grip CCW and CW
being fed from the axis engraving sample program that loads in emc2
the grip was flipping back and forth crazily
like the two solenoids were fighting each other
and i got to thinking that maybe by holding one solenoid and pulsing the other
speed control could be achieved and maybe position also
were still not really sure if we'll include the limit switches or not
as they may not really be necessary
Time to create page: 0.142 seconds
