Setting initval of a spinbox in hal
21 Apr 2013 19:43 - 21 Apr 2013 19:44 #32959
by mariusl
Regards
Marius
www.bluearccnc.com
Setting initval of a spinbox in hal was created by mariusl
Hi All,
Is there a way to set the <initval> of a spinbox from HAL? I need to read a value from the .INI file and then set the spinbox for that value.
Regards
Marius
www.bluearccnc.com
Last edit: 21 Apr 2013 19:44 by mariusl.
21 Apr 2013 23:20 #32966
by ArcEye
Replied by ArcEye on topic Setting initval of a spinbox in hal
Hi
Quick answer - No
The value is set at either 100 or <initval> in the .xml file if set.
By the time the pins are available, the panel has been created from the .xml file
Long answer - Anything is possible, if you want to do it.
Have a look at /usr/share/pyshared/pyvcp_widgets.py
The code for the spinbox widget starts at line 763
You could rewrite the widget so that it creates a param called initparam and updates when this changes.
And here it is working - ignore the other stuff, I just added it to a sim to test it
This is not polished, I am not a python programmer, but it works.
(you need to delete /usr/lib/python2.6/dist-packages/pyvcp_widgets.pyc and insert this code into pyvcp_widgets.py or it will run the old compiled code)
Quick answer - No
class pyvcp_spinbox(Spinbox):
""" (control) controls a float, also shown as text
reacts to the mouse wheel
<spinbox>
[ <halpin>"my-spinbox"</halpin> ]
[ <min_>55</min_> ] sets the minimum value to 55
[ <max_>123</max_> ] sets the maximum value to 123
[ <initval>100</initval> ] sets intial value to 100 TJP 12 04 2007
</spinbox>
# FIXME: scale resolution when shift/ctrl/alt is held down?
n=0
def __init__(self,master,pycomp,halpin=None, halparam=None,
min_=0,max_=100,initval=0,resolution=1,format="2.1f",**kw):
self.v = DoubleVar()
if 'increment' not in kw: kw['increment'] = resolution
if 'from' not in kw: kw['from'] = min_
if 'to' not in kw: kw['to'] = max_
if 'format' not in kw: kw['format'] = "%" + format
kw['command'] = self.command
Spinbox.__init__(self,master,textvariable=self.v,**kw)
if halpin == None:
halpin = "spinbox."+str(pyvcp_spinbox.n)
pyvcp_spinbox.n += 1
self.halpin=halpin
if halparam == None:
halparam = "spinbox.initparam"
self.halparam=halparam
if initval < min_:
self.value=min_
elif initval > max_:
self.value=max_
else:
self.value=initval
self.oldvalue=min_
self.init=self.value
self.oldinit=self.init
self.format = "%(b)"+format
self.max_=max_
self.min_=min_
self.resolution=resolution
self.v.set( str( self.format % {'b':self.value} ) )
pycomp.newpin(halpin, HAL_FLOAT, HAL_OUT)
pycomp.newpin(halparam, HAL_FLOAT, HAL_IN)
self.bind('<Button-4>',self.wheel_up)
self.bind('<Button-5>',self.wheel_down)
pycomp[self.halparam] = self.init
def command(self):
self.value = self.v.get()
def update(self,pycomp):
pycomp[self.halpin] = self.value
if self.value != self.oldvalue:
self.oldvalue=self.value
self.init = pycomp[self.halparam]
if self.init != self.oldinit:
self.v.set( str( self.format % {'b':self.init} ) )
self.value=self.init
def wheel_up(self,event):
self.value += self.resolution
if self.value > self.max_:
self.value = self.max_
def wheel_down(self,event):
self.value -= self.resolution
if self.value < self.min_:
self.value = self.min_
The following user(s) said Thank You: AndrewL
22 Apr 2013 00:26 #32968
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Setting initval of a spinbox in hal
Damnnnn!! some guys are clever.
Thanks a lot man I will test this out and include in my screen.
I think this should be standard so that one can set values instead of hard coding them into the screen. I will use these on my plasma setup.
Regards
Marius
www.bluearccnc.com
22 Apr 2013 01:09 - 22 Apr 2013 03:41 #32971
by mariusl
Regards
Marius
www.bluearccnc.com
Arceye, I commented out the spinbox and added your new code. Then I deleted the pyc file and loaded my controller. This is the error that comes up. I am no good at python so I dont even know here to start looking.
Error constructing spinbox({'max_': 99, 'format': '3.0f', 'initval': 54, 'width': '3', 'min_': 1, 'halpin': 'Spin-TravelHeight', 'resolution': 1, 'justify': 'right'}):
Duplicate item name 'spinbox.initparam'
I also found more than one instance of the file.
./usr/share/pyshared/pyvcp_widgets.py
./usr/lib/pymodules/python2.6/pyvcp_widgets.py
./usr/lib/python2.6/dist-packages/pyvcp_widgets.pyc
P.S. I think it might work with one only spinbox. I have several. Can you test it with more than one please?
Regards
Marius
www.bluearccnc.com
Last edit: 22 Apr 2013 03:41 by mariusl.
22 Apr 2013 13:41 #32979
by ArcEye
Hi
Yes the error is because you have more than one spinbox
I will change it so that the instances get numbered
This code was just a first draft
Regards the other copies of the file, I had these too.
I deleted all of them and created a symlink to the .py file in /usr/share
at each location
I found it was only the .pyc in python2.6 that regenerated
I,ll get back later
at each location
I,ll get back later
22 Apr 2013 15:23 - 22 Apr 2013 15:28 #32980
by ArcEye
Hi
Have amended the code slightly so that the initparams number the same as the spinboxes
If you name your spinboxes with a suffixed number starting at 0, as I did, it is easy to see which initparam matches which spinbox
The new code is
and 'proof of life'
Don't forget to delete all the .pyc files, replace the various .py files with symlinks to /usr/share/pyshared/pyvcp_widgets.py and then you won't get into difficulties with old code being used.
The new code is
<spinbox>
</spinbox>
n=0
if halpin == None:
self.halpin=halpin
halparam = "spinbox.initparam."+ str(pyvcp_spinbox.n)
if initval < min_:
self.value=min_
self.value=max_
else:
self.value=initval
self.oldvalue=min_
self.max_=max_
self.min_=min_
def command(self):
and 'proof of life'
Last edit: 22 Apr 2013 15:28 by ArcEye.
The following user(s) said Thank You: mariusl
22 Apr 2013 15:28 #32981
by mariusl
Regards
Marius
www.bluearccnc.com
Awesome stuff man. I suggest that you submit this as a featured change. It is very handy.
Just to make sure I dont screw this up.
This is where the real code sits:
These two are replaced by a symlink:
Regards
Marius
www.bluearccnc.com
22 Apr 2013 15:36 #32982
by ArcEye
Almost
Just delete all the .pyc (python compiled) libs, those are generated automatically from the new .py file next time it is run
You need to symlink the /usr/share/pyshared/pyvcp_widgets.py to everywhere it occurred, having deleted the old .py file first of course
I actually had it in /usr/lib/python2.5 as well, but you probably don't have that
22 Apr 2013 15:48 #32983
by mariusl
Regards
Marius
www.bluearccnc.com
It works like a charm. Thanks a lot ArcEye.
Regards
Marius
www.bluearccnc.com
23 Apr 2013 18:21 - 23 Apr 2013 21:49 #33050
by ArcEye
Hi
If you or anyone else wants to, this patch will change the spinbox, scale and dial widgets, so that there is a parameter pin which allows the initial setting through HAL.
EDIT: It is not just for initialisation, it can be used to change the value displayed and output directly.
The methodology and naming is the same as I did for the spinbox, if you number your widgets with a suffix starting at 0, they will match the relevant initparams.
I don't know how generally useful this is, so don't think I will bother submitting for inclusion in the release.
(rename to params.patch)
Last edit: 23 Apr 2013 21:49 by ArcEye.
Time to create page: 0.488 seconds
