Z axis configuration
24 May 2010 01:42 #2980
by dcassyc1
Z axis configuration was created by dcassyc1
I'm having difficulty setting up my Z axis. When I test the axis in step.conf the travel is OK, but after I run EMC, and home Z axis, it reads 8 inches. The scaling is off by one half. The servo motor has a 500 line encoder. and ratio is 14 to 18 timing belt to a 10 tpi lead screw. Safe travel is 8"
After it homes it reads 8" on the Z register, but only goes down 4" before it trips the software limit. Would anyone have an idea what 's wrong?
thanks,
Denis
thanks,
Denis
24 May 2010 10:43 #2984
by Rick G
Replied by Rick G on topic Re:Z axis configuration
First check what your software limits are set at, also double check the actual movement of the z axis for say a 1" move and adjust if necessary.
Rick G
Rick G
26 May 2010 02:54 #3010
by dcassyc1
Replied by dcassyc1 on topic Re:Z axis configuration
Thanks for the reply Rick. Actually, I'd already tried that and it didn't make a difference. I couldn't think of anything else to do and in desperation I ended up making a new configuaration file with the same values for everthing and that worked out OK.
First I deleted all references to that machine in the /configs directory. There were 2 entries in the /configs directory for that machine name consisting of a directory and a step.conf file. Then I made up a new configuration file, tested it and it worked great.
cheers,
Denis
cheers,
Denis
26 May 2010 10:17 #3015
by Rick G
Glad to hear you are up and running. I wonder if you possibly had an offset on the z axis.
Rick G
Rick G
