problems with using Montenc-Lite card
- schlieffen
07 Jun 2010 08:50 - 08 Jun 2010 11:25 #3085
by schlieffen
problems with using Montenc-Lite card was created by schlieffen
Hello,
We want to do some experiments using the Motenc-Lite card with the
EMC2_2.3.1 software. The graphical interface we are using is TKEMC.
The problem we are facing is as follows:
1. Start emc and select montec in My Configurations file folder.
2. Clear the E-STOP condition and turn the machine on (by pressing F1 then F2).
3. When press Home button, an error message Can't do that (EMC_AXIS_HOME) in auto mode with the interpreter idle occurs.
If we skip the third step above, then the problem occurs as follows:
3. Load the file cds.ngc.
4. Put the stock to be milled on the table.
5. Set the proper offsets for each axis by jogging, an error message can't do that (EMC_AXIS_JOG) in auto mode with the interpreter idle occurs.
If we skip the fifth step above, then the problem occurs as follows:
5. Run the program, and an error message Linear move on line 14 would exceed limits occurs.
May anyone help us to solve the above problem please?
Thank you,
Schlieffen Wang
Engineer
Accupower Techonlogies
email: This email address is being protected from spambots. You need JavaScript enabled to view it.
Thank you,
Schlieffen Wang
Engineer
Last edit: 08 Jun 2010 11:25 by BigJohnT. Reason: remove smart quotes which cause the message not to display
08 Jun 2010 11:29 #3089
by BigJohnT
Replied by BigJohnT on topic Re:problems with using Montenc-Lite card
If you copy and paste from a word processor that has smart quotes the text will not display in the forum. I removed all the quotes from your message so it would show up... I couldn't tell which ones were smart quotes this morning as my eyes are a little fuzzy.
I don't know anything about the motec card so I can't help with that.
Time to create page: 0.054 seconds
