setup for gantry with linuxcnc 2.7.5.
26 Jul 2016 15:28 #78045
by mpvriens
Replied by mpvriens on topic setup for gantry with linuxcnc 2.7.5.
Hi JT,
when doing so linux gives a lot of errors and wouldn't start:
Error in startup script: no such variable, and a configuration error is preventing linuxCNC from starting
27 Jul 2016 14:00 #78068
by BigJohnT
Replied by BigJohnT on topic setup for gantry with linuxcnc 2.7.5.
I was able to reproduce the bug and a temporary work around is to open a terminal and issue the following commands to start master.
JT
export LINUXCNCVERSION=999
export LINUXCNC_EMCSH=wish
export LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc/
linuxcnc name_of_ini_file.ini
JT
27 Jul 2016 14:27 #78072
by mpvriens
Hi JT,
Thanks for your quick respond, this works , and for tuning this machine i can work with it.
Marius
Marius
27 Jul 2016 21:26 #78082
by BigJohnT
Also note that the key to setting up a twin motor gantry is in setting the [KINS] section of the ini correct.
linuxcnc.org/docs/devel/html/config/ini-...g.html#_kins_section
If your using online docs make sure your looking at Master.
JT
JT
The following user(s) said Thank You: mpvriens
28 Jul 2016 12:10 #78094
by BigJohnT
To update a buildbot deb (the bug was fixed) in a terminal:
And you should be good to go with master again.
JT
sudo apt-get update
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be upgraded:
linuxcnc-doc-en linuxcnc-uspace
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.8 MB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue [Y/n]? y
JT
29 Jul 2016 06:10 #78126
by mpvriens
Thank you very much JT
Works fine now!
Marius
Works fine now!
Marius
21 Apr 2017 11:52 #91774
by zarfld
Replied by zarfld on topic setup for gantry with linuxcnc 2.7.5.
Hello,
this is my 1st post in this Forum. (I'm 36 and a newbie in Linux and LinuxCNC.)
anyway i hope you could help on my issue.
(It can be that it is a misinterpretation from my side)
according that documentation the extended functionality of trivkins seems available since 2.7.4.
Ive installed from actual IsoImage and ran updates so it shows 2.7.8 - but when trying to start EMC it shows
trivkins: Unknonwn parameter 'coordinates'
so i'm not sure if i need to install a different version - to get my Gantry up and running
BR
Dominik
BR
Dominik
21 Apr 2017 18:39 #91803
by zarfld
ok i installed from master (2.8pre) and it seems to work
Time to create page: 0.298 seconds
