Hal-Histogram
- Topic Author
- Thank you received: 1369
29 Jul 2016 04:08 #78124
Hal-Histogram was created by Todd Zuercher
Is there a way to use Hal-Histogram to monitor a parameter?
such as for example to log the data from motion.servo.last-period-ns.
29 Jul 2016 12:38 - 29 Jul 2016 12:39 #78134
by dgarrett
hal-histogram works for pins only but a pin is provided for
measuring each thread time (in clocks).
Example:You will have to adjust the minvalue,binsize,nbins either
interactively or from the command line.
Ref:
Replied by dgarrett on topic Hal-Histogram
Example:
$ hal-histogram servo.thread.time
Ref:
$ hal-histogram --help
Usage:
hal-histogram --help | -?
or
hal-histogram [Options] [pinname]
Options:
--minvalue minvalue (minimum bin, default: 0)
--binsize binsize (binsize, default: 100)
--nbins nbins (number of bins, default: 50)
--logscale 0|1 (y axis log scale, default: 1)
--text note (text display, default: "" )
--show (show count of undisplayed nbins, default off)
--verbose (progress and debug, default off)
Notes:
1) LinuxCNC (or another Hal application) must be running
2) If no pinname is specified, default is: motion-command-handler.time
3) This app may be opened for 5 pins
4) pintypes float, s32, u32, bit are supported
5) The pin must be associated with a thread supporting floating point
For a base thread, this may require using:
loadrt motmod ... base_thread_fp=1
Last edit: 29 Jul 2016 12:39 by dgarrett.
- Topic Author
29 Jul 2016 13:06 - 29 Jul 2016 13:07 #78136
Replied by Todd Zuercher on topic Hal-Histogram
I knew all that. but the pin servo.thread time is not equivalent of the parameter motion.servo.last-period. It looks like servo.thread.time is the amount of time used to execute all the functions. Useful info but tells you nothing about system latency unless your system can't process the servo-thread fastenough. Where as motion.servo.last-period is the length of the actual servo thread including jitter There are a number of Parameters that I could see it being very useful (or at least interesting) to observe with Hal-Histogram
My question, is there a workaround to make Hal-Histogram work with parameters, like Halmeter or Halscope can?
Last edit: 29 Jul 2016 13:07 by Todd Zuercher.
29 Jul 2016 13:58 #78138
by dgarrett
No-- hal-histogram provides input pins which must be connected by hal signals
to appropriate hal output pins. You could modify the source code to
change certain parameters to pins for your purposes.
An alternative method uses hal-histogram in conjunction with the
hal latencybins component that is used by the latency-histogram program.
(The latency-histogram program is not usable when linuxcnc is running).
Thisi latencybins component provides a hal pin for latency, and it
can be connected to hal-histogram using the method shown in the image.
- Topic Author
29 Jul 2016 15:13 #78143
Would it be possible to write a simple userspace component that could input a parameter value and output that as a hal output pin? (or might something like this already exist?)
24 Jan 2017 13:13 #86554
by DomCa
Replied by DomCa on topic Hal-Histogram
I am measuring latency on my system with the above method. I now wonder if it would make any difference measuring the base thread instead of the servo thread.
Would it be possible to measure the base-thread with the above? Exchanging the "servo-thread" with "base-thread" did not work for me...
DomCa
DomCa
- Topic Author
24 Jan 2017 13:37 #86557
I think any thread that it is associated with has to be a floating point thread,
To load a base thread with a floating point use loadrt motmod ... base_thread_fp=1 (With the ... being what ever else what already on that line in your hal file.)
24 Jan 2017 14:00 #86558
by DomCa
Hi Todd,
sorry to ask again, but I only have the servo-thread and motmoto is allready loaded.
I am using the axis simulation that is automatically selected when starting linuxcnc.
Can you give me some guidance on how to get a 25ns instead of the 1000ns base thread that I can analyze with the histogram?
DomCa
DomCa
- Topic Author
24 Jan 2017 14:34 #86562
The line would be something like this.but it could look more like this using ini variables.
loadrt motmod base_period_nsec=25000 base_thread_fp=1 servo_period_nsec=1000000 num_joints=3
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD base_thread_fp=1 servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
25 Jan 2017 07:02 #86598
by DomCa
Thanks Todd,
Your help is realy appreaciated. However, I am getting an error because motmod is allready loaded. I am still using the axis Simulation.
If there is an easy fix, I would be glad.
However, I'm still learning inuxCNC and that goes beyond my knowledge at the moment. I will go on digging into LinuxCNC and come back.
Until then I will assume that the latency I am getting for the 1000ns thread is similar fo the 25ns thread and go on building my CNC.
DomCa
DomCa
Time to create page: 0.134 seconds
