Threading with A B phase only?
27 Sep 2016 13:13 #80997
by newbynobi
Replied by newbynobi on topic Threading with A B phase only?
A little bit off topic, but...
if I add such a switch to my lathe spindle, how fast will the switch react, or better ask what rpm might it be able to count?
It would be easier than adapt an encoder 1:1 to the spindle.
Norbert
Norbert
27 Sep 2016 13:30 #80999
It doesn't really matter as long as it is consistent at the speed that you are running at.
And spindle-synchronised moves normally happen at fairly low spindle speeds.
Replied by andypugh on topic Threading with A B phase only?
28 Sep 2016 00:39 #81019
by Mtndrew77
Replied by Mtndrew77 on topic Threading with A B phase only?
So the switch is PNP, and I got it all hooked up. I was expected one pulse per rev and instead I got 8. After backing out the sensor ring I confirmed eight slots. So I'm sort of back where I started but I a smaller scale. How do I get 8 pulses down to one?.
28 Sep 2016 08:38 #81027
Probably the easiest way is to make a 1-slot sensor ring. And possibly swap the proximity sensor for an NPN. They are very cheap on eBay.
- Thank you received: 1369
28 Sep 2016 15:50 #81041
Replied by Todd Zuercher on topic Threading with A B phase only?
For a test you might be able to put a piece of tape over 7 of the slots. And if that works fill them in with something more permanent.
28 Sep 2016 23:50 #81065
by Mtndrew77
Unfortunately for me the sensor ring is also the lock nut that holds the back spindle bearing in. I going to try soldering in the extra holes for now to get it going. Then I can make a new ring. I'll let you know how it all works out.
24 Oct 2016 16:53 #81995
by Mtndrew77
I soldered up the holes and then filed them. It worked beautifully! Thanks for all the help.
I posted some pictures in the show your stuff section
- MacGalempsy
06 Feb 2017 14:08 #87392
by MacGalempsy
Replied by MacGalempsy on topic Threading with A B phase only?
How does one go about programming the proximity switch as the index pulse? If the switch covers a range of counts, is it possible to capture the counts on the rising and falling edges, then move to the middle?
06 Feb 2017 14:18 #87393
The rising edge will be used as the index.
This is perfectly OK, as long as it is consistent.
16 Feb 2017 16:27 #88059
by Stormbird
Replied by Stormbird on topic Threading with A B phase only?
Hi I am a hobbyist and I too have (just acquired) an Emcomat 20E with faulty electronics (so faulty that spindle drive nor feed drive works) and want to upgrade/swap out all the electronics to a modern control system (with DRO and quasi-CNC). I could maybe keep the stepper motors for feed and for the thread cutting auto insert/withdrawal, but will fit a smaller spindle drive motor to match my inverter for domestic supply which has a 3hp max limit (so will replace with a 2.2kw 3 phase dual voltage motor). I have found very little info from EMCO on the electronics although I do have a complete manual. In particular I cannot find any info on the Linear encoders to usefully find a matching DRO system, nor what program could set pitch diameters to the the existing leadscrew feed motor for thread cutting. In terms of control, I would ideally like to have allthe original program functions and add to those an ability to cut diagonal paths (in other words drive X and Z simultaneously). I would be very grateful to hear what you have done and at what cost. Kind regards, Adam
Time to create page: 0.101 seconds
