dual motors on Y
08 Dec 2016 17:32 #83786
by neil52
dual motors on Y was created by neil52
I have dual motors on Y , should each driver be hooked to the same pin on on the bob? might seem like stupid question but I am complete newby.
The following user(s) said Thank You: Tchefter
08 Dec 2016 17:40 #83788
Replied by andypugh on topic dual motors on Y
That is one way to do it, but rarely the best way.
It is generally better to run the two motors from separate io pins, and also from separate step generators (especially if the motors turn in opposite directions, though there are many ways to switch the direction of a stepper motor or servo motor)
For a dual-motor setup there is a lot to be said for running the current development version of LinuxCNC as it does this job better.
09 Feb 2017 17:37 #87682
by neil52
Replied by neil52 on topic dual motors on Y
I have set up as you said, function alright to start with now one motor will only turn one direction and sometimes intermittenly. I can swap drivers and the problem swaps motors. Only thing I can think of is driver has gone bad. I s there anything else that might cause this problem?
Thanks. Neil
Thanks. Neil
- Thank you received: 1369
09 Feb 2017 18:14 #87687
Replied by Todd Zuercher on topic dual motors on Y
Did you swap at the motor or the driver? Bad cabling, or pug connections can often cause problems. Same goes for the control signal wiring Try to confirm those are not the problem before declaring the driver faulty.
09 Feb 2017 18:30 #87689
by neil52
I swapped at the driver, I am going to recheck control signal wiring again. Thanks for the input
Time to create page: 0.145 seconds
