Biesse Rover 346 Retrofit
11 Jan 2017 05:55 #85605
Replied by PCW on topic Biesse Rover 346 Retrofit
A couple things:
The 7I74s RJ45 lights are not functional
All sserial cards use straight through Cat5E/Cat6 cables
The likely reason the 7I70/7I71 cards do not start is that they have not been enabled in the hal file
(since there are more than 8 sserial ports in the config there are 2 sserial ports, port_0 (3 7I77 channels only)
and port_1 (8 channels on 7I74) Port 1 must be specifically enabled in the hal file
11 Jan 2017 06:24 #85606
by bevins
DOH!!!, i'll chek that tomorrow, thanks,
Bob
Replied by bevins on topic Biesse Rover 346 Retrofit
A couple things:
Bob
11 Jan 2017 13:40 #85610
by bevins
Thank a bunch. All boards are up and running......Woooo Hoooo!!!!
A couple things:
11 Jan 2017 14:09 - 11 Jan 2017 14:53 #85611
by bevins
So I have my 7i74 with 7i70 and 7i71, waiting toi receive my second 7i71.
I have:
hm2_5i25.0.7i70.1.0.input-00 - input-47
hm2_5i25.0.7i71.1.2.output-00 - output-47
When I add another 7i71 will it be hm2_5i25.0.7i71.2.1.input-00 - input-47 ?
or hm2_5i25.0.7i71.1.1.input-00 - input-47?
I would assume hm2_5i25.0.7i71.1.1.input-00 - input-47 because of the hm2_5i25.0.7i77.0.0.input-00 - input-31
So it would be board type (7i71).port on 5i25(1). port on card(0-8) , is this correct?
I have:
Last edit: 11 Jan 2017 14:53 by bevins.
11 Jan 2017 15:52 #85613
hm2_5i25.0.7i71.1.1.input-00 is possible (if a 7I71 was plugged into 7I74 channel 1)
hm2_5i25.0.7i71.2.x.input-00 is not possible on that particular firmware since you only have 2 sserial ports
(0 and 1, port_0 used for the 3x 7I77 channels and port_1 for the 8 7I74 channels )
its possible to have 3 ports (a config could be made so the 7I74 had 2 ports (1 and 2) each with 4 channels)
There is an alternate sserial device naming scheme that uses the last 4 digits of the sserial card
unit number for the unique part of the hal name. This scheme has the advantage that you car re-arrange
channels and ports and everything remains the same
11 Jan 2017 16:26 #85615
by bevins
OK thanks, that answers my question. As long as I dont move to a different port on the 7i74, they will always stay the same and I can live with this scheme...
Bob
Bob
11 Jan 2017 22:34 #85631
Replied by andypugh on topic Biesse Rover 346 Retrofit
I prefer the alternative scheme.
You enable it in the "loadrt hostmot2" line in the HAL.
loadrt hostmot2 use_serial_numbers=1
12 Jan 2017 04:07 - 12 Jan 2017 04:10 #85649
by bevins
Then use the last four digits of the serial numbers on the cards instead of the 7i74 port numbers?
Whats the advantage beside being able to move from port to port without changing the hal?
I see it as a disadvantage because you have to type more characters...lol
I am going to try it though.
Bob
You enable it in the "loadrt hostmot2" line in the HAL.loadrt hostmot2 use_serial_numbers=1
Bob
Last edit: 12 Jan 2017 04:10 by bevins.
12 Jan 2017 15:01 #85654
by bevins
There are 3 RS422 channels on the 7i77? I thought there was only one.
A couple things:
12 Jan 2017 15:07 #85655
Yes:
channel 0 = digital I/O
channel 1 = analog out
channel2 = expansion port (TB6)
Time to create page: 0.314 seconds
