linuxcnc updated and now have rounding corners
09 Jan 2017 19:33 #85543
by nodyeliab
linuxcnc updated and now have rounding corners was created by nodyeliab
Hello, I've recently took an update to linuxcnc and now all my corners are rounding but they weren't before the update. Is there a setting to put this back so it doesn't round anymore? I've looked through the thread here and found that the G64 P.### works but I would need to add this to all of my past NC files. I would prefer to have it setup like it was before, prior to the update.
Thanks for any help!
10 Jan 2017 20:05 #85584
by BigJohnT
Replied by BigJohnT on topic linuxcnc updated and now have rounding corners
AFAIK this has never changed. G64 is the default setting when you start LinuxCNC. G64 is just blending G64 tells the planner to sacrifice path following accuracy in order to keep the feed rate up. What can change the path deviation is the acceleration of the axes.
linuxcnc.org/docs/2.7/html/user/user-concepts.html
JT
JT
10 Jan 2017 20:14 #85588
by nodyeliab
Replied by nodyeliab on topic linuxcnc updated and now have rounding corners
Thank you, do you know why after upgrading linuxcnc it would just start rounding? It wasn't before I took the latest update.
14 Jan 2017 12:35 - 14 Jan 2017 13:06 #85744
by Rick G
Replied by Rick G on topic linuxcnc updated and now have rounding corners
You could add G64 P.### to your start up in your ini file... It will be superseded by any program that set G64 that is later run.
linuxcnc.org/docs/2.6/html/config/ini_co...sub:RS274NGC-section
Also
Depending on the version you upgraded from , currently...
In your ini file...
The new Trajectory Planner (TP) is on by default.
linuxcnc.org/docs/ja/html/config/ini-config.html
Rick G
Also
2.10. [TRAJ] Section
Warning
If you have no TP settings in your [TRAJ] section - LinuxCNC defaults to:
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 0
ARC_BLEND_OPTIMIZATION_DEPTH = 50
ARC_BLEND_GAP_CYCLES = 4
ARC_BLEND_RAMP_FREQ = 100
In your ini file...
Rick G
Last edit: 14 Jan 2017 13:06 by Rick G.
18 Jan 2017 12:32 #86048
It is possible that, previously, the maximum machine speed was limited by the 1-block lookahead, so the behaviour would have been the same if the machine could move as fast, but the machine simply wasn't moving as fast. (the new Trajectory Planner is capable of moveing much more rapidly, which was the point of it).
Did you do a complete re-installl or just an update? Is it possible that the machine acceleration limits were changed?
Replied by andypugh on topic linuxcnc updated and now have rounding corners
Time to create page: 0.381 seconds
