USB device suddenly not recognized by hal_input
11 Jan 2017 15:59 #85614
by Wirewrap
USB device suddenly not recognized by hal_input was created by Wirewrap
Something has happened.
This LinuxCNC machine has been in use for a couple of weeks and my USB pendant has been working with hal_input as it was supposed to do.
The pendant is recognized by UDEV and assigned to group plugdev.
LinuxCNC 2.7.8
Now, suddenly hal_input is not finding the pendant. but hidraw2 still belongs to plugdev.
I tried with hidconfig to diagnose, it puts an asterisk on this device.
sudo hidconfig finds the device without an asterisk.
hexdump /dev/hidraw2 works without sudo!
Triedthis does not solve the problem.
What else can I try?
LinuxCNC 2.7.8
uname -a
Linux debianRT 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
ls -l /dev/hid*
crw------- 1 root root 252, 0 Jan 11 16:30 /dev/hidraw0
crw------- 1 root root 252, 1 Jan 11 16:30 /dev/hidraw1
crw-rw-rwT 1 root plugdev 252, 2 Jan 11 16:30 /dev/hidraw2
crw-rw-rwT 1 root plugdev 252, 3 Jan 11 16:30 /dev/hidraw3
Tried
sudo chmod 0666 /dev/hidraw2
sudo chown la.la /dev/hidraw2
18 Jan 2017 12:10 #86044
Replied by andypugh on topic USB device suddenly not recognized by hal_input
Did you get this fixed?
I had a machine that used to "lose" USB devices. I never really tried to get to the bottom of it, as it was a joypad only really useful for milling, and I stopped milling with that machine.
I would be tempted to try blindly tweaking USB settings in the BIOS.
18 Jan 2017 15:36 #86055
by Wirewrap
Replied by Wirewrap on topic USB device suddenly not recognized by hal_input
Yes,
it is fixed now.
I tried some different idéas, and suddenly the pendant was online again. Not sure which thing was the actual fix.
it is fixed now.
Time to create page: 0.064 seconds
