Help Create a shortcut for configuration
- PABLOSAN2903
18 Jan 2017 21:19 #86094
by PABLOSAN2903
Help Create a shortcut for configuration was created by PABLOSAN2903
The following is where I arrive:(
Name___tc211
Comment__test
command__home/pablo/linuxcnc-dev/scripts/linuxcnc /home/pablo/linuxcnc-dev/configs/tc211(Command is correct??)
After
Compile and install components
If you create a component the same must be compiled and installed. In order to do this the following commands should be made.
Browse to the base directory of the linuxcnc installation, normally linuxcnc-dev:
$ cd linuxcnc-dev
$ . ./scripts/rip-enviorment
$ cd configs/YOUR_CONFIG_NAME
$ halcompile --install YOUR_COMPONENT_NAME
There is no folder or directory, must first add a folder? Example: linuxcnc_dev / configs / tc211, created a folder and then did this.
Can say i'm doing wrong...Gracias
Name___tc211
Comment__test
Attachment not found
After
$ cd linuxcnc-dev
19 Jan 2017 07:19 #86131
Replied by rodw on topic Help Create a shortcut for configuration
In the linuxcnc chooser there is an option to create a shortcut on the desktop. I used that to create the shortcut. I've added the rip-environment to a startup command in the IDE. I'm using Mint 17.3
I then copied the desktop shortcut and edited it to run the last config I have been using becasue I am still developing my machine.
19 Jan 2017 15:12 #86153
by BigJohnT
Replied by BigJohnT on topic Help Create a shortcut for configuration
Most modern distro's support the right click with options like send to desktop and as rod points out the configuration selector has a check box to create a desktop shortcut If LinuxCNC is installed the command is linuxcnc linuxcnc/configs/config_directory/config_name.ini you can test the command in a terminal window then right click on the desktop and create a launcher.
JT
JT
Time to create page: 0.071 seconds
