can you add a measurement field and a go to button to emc2
07 Feb 2017 14:17 #87458
Replied by andypugh on topic can you add a measurement field and a go to button to emc2
The config picker looks for INI files, is your gladevcp referenced by any INI file?
07 Feb 2017 15:27 #87461
by Pause22
Replied by Pause22 on topic can you add a measurement field and a go to button to emc2
i think it was saved as a .glade file should it be .INI?
thanks
thanks
07 Feb 2017 16:36 #87464
No, it should be a .glade file, but it needs to be added to a LinuxCNC config, as described in the link I gave you.
07 Feb 2017 16:55 #87468
by Pause22
I did as it said in the link made a directory in linuxcnc config and saved it ,but i cant see it when i try to find it using config picker..
07 Feb 2017 20:39 #87485
Does your new directory contain the files from the link in the tutorial?
One of those is an INI file.
07 Feb 2017 22:30 #87497
by Pause22
No it doesn't contain an INI file,also I created a folder is that the same as a directory?
07 Feb 2017 22:50 #87498
Download the folder, save it into your config folder.
(yes, folder / directory, same thing)
goinglinux.com/articles/DirectoryVsFolder.html
08 Feb 2017 11:45 #87522
by Pause22
sorry i think i must be overthinking this,but where is the file i,m going to download ?
08 Feb 2017 11:48 #87523
On page 2 of the tutorial (section 6). I assume you have got that far, because the first page doesn't mention making a directory.
08 Feb 2017 15:04 #87568
by Pause22
thanks for your patience,,i have got there now ,next problem i don't seem to have Gedit
Time to create page: 0.391 seconds
