LinuxCNC exits after launch
30 Jan 2017 07:47 #86951
by steveb48
LinuxCNC exits after launch was created by steveb48
Did fresh install of 2.7 and tried to run various sim configs. All exit right after launch. Upgrading to 2.7.8 didn't help. Any ideas?
Thanks,
Steve
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/steve/linuxcnc/configs/sim.axis'
Machine configuration file is 'gantry.ini'
INIFILE=/home/steve/linuxcnc/configs/sim.axis/gantry.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/gantrysim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated-gantry-home.hal
Starting DISPLAY program: axis
task: main loop took 0.013756 seconds
task: main loop took 0.013902 seconds
Killing task linuxcncsvr, PID=4609
Killing task milltask, PID=4653
task: 1286 cycles, min=0.000024, max=0.013902, avg=0.002248, 2 latency excursions (> 10x expected cycle time of 0.001000s)
Debug file information:
python: swrast/s_renderbuffer.c:588: map_attachment: Assertion `srb->Map' failed.
/usr/bin/linuxcnc: line 856: 4656 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4609
PID TTY STAT TIME COMMAND
4653
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000004fe74000 (usable)
[ 0.000000] BIOS-e820: 000000004fe74000 - 000000004fe76000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000004fe76000 - 000000004fe97000 (ACPI data)
[ 0.000000] BIOS-e820: 000000004fe97000 - 000000004ff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Computer Corporation Dimension 2400 /0G1548, BIOS A05 12/02/2003
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x4fe74 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FF0000000 write-back
[ 0.000000] 2 base 04FF00000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36418000 - 37204000
[ 0.000000] ACPI: RSDP 000feb80 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fd22a 00034 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: FACP 000fd25e 00074 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: DSDT fffcc0f1 02404 (v01 DELL dt_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 4fe74000 00040
[ 0.000000] ACPI: SSDT fffce4f5 000A7 (v01 DELL st_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: APIC 000fd2d2 0006C (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd33e 00028 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 390MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0004fe74
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0004fe74
[ 0.000000] On node 0 totalpages: 327172
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5a18200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 781 pages used for memmap
[ 0.000000] HighMem zone: 99177 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 4ff00000 (gap: 4ff00000:aed00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77b2000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 324615
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=cc8ed2dc-71f6-4453-a624-1ca7c9984960 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2618144 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0004fe74)
[ 0.000000] Memory: 1274664k/1309136k available (3495k kernel code, 34024k reserved, 1237k data, 416k init, 399832k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5408000 soft=f540a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2658.038 MHz processor.
[ 0.008004] Calibrating delay loop (skipped), value calculated using timer frequency.. 5316.07 BogoMIPS (lpj=10632152)
[ 0.008011] pid_max: default: 32768 minimum: 301
[ 0.008093] Security Framework initialized
[ 0.008103] AppArmor: AppArmor disabled by boot time parameter
[ 0.008136] Mount-cache hash table entries: 512
[ 0.008473] Initializing cgroup subsys cpuacct
[ 0.008479] Initializing cgroup subsys memory
[ 0.008494] Initializing cgroup subsys devices
[ 0.008498] Initializing cgroup subsys freezer
[ 0.008502] Initializing cgroup subsys net_cls
[ 0.008505] Initializing cgroup subsys blkio
[ 0.008518] Initializing cgroup subsys perf_event
[ 0.008568] CPU0: Hyper-Threading is disabled
[ 0.008573] mce: CPU supports 4 MCE banks
[ 0.008586] CPU0: Thermal monitoring enabled (TM1)
[ 0.008675] SMP alternatives: switching to UP code
[ 0.015587] ACPI: Core revision 20120320
[ 0.040239] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.040601] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.080351] CPU0: Intel(R) Pentium(R) 4 CPU 2.66GHz stepping 09
[ 0.084004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.084004] ... version: 0
[ 0.084004] ... bit width: 40
[ 0.084004] ... generic registers: 18
[ 0.084004] ... value mask: 000000ffffffffff
[ 0.084004] ... max period: 0000007fffffffff
[ 0.084004] ... fixed-purpose events: 0
[ 0.084004] ... event mask: 000000000003ffff
[ 0.092043] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.092103] Brought up 1 CPUs
[ 0.092108] Total of 1 processors activated (5316.07 BogoMIPS).
[ 0.092683] devtmpfs: initialized
[ 0.093088] PM: Registering ACPI NVS region [mem 0x4fe74000-0x4fe75fff] (8192 bytes)
[ 0.093258] dummy:
[ 0.093351] NET: Registered protocol family 16
[ 0.093555] ACPI: bus type pci registered
[ 0.093909] PCI: PCI BIOS revision 2.10 entry at 0xfbbbf, last bus=1
[ 0.093913] PCI: Using configuration type 1 for base access
[ 0.094945] bio: create slab <bio-0> at 0
[ 0.095102] ACPI: Added _OSI(Module Device)
[ 0.095107] ACPI: Added _OSI(Processor Device)
[ 0.095112] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.095117] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.096132] ACPI: EC: Look up EC in DSDT
[ 0.114030] ACPI: Interpreter enabled
[ 0.114051] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.114108] ACPI: Using IOAPIC for interrupt routing
[ 0.148327] ACPI: No dock devices found.
[ 0.148339] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.149914] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.152900] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.152906] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.152910] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.152915] pci_root PNP0A03:00: host bridge window [mem 0x80860000-0xfebfffff] (ignored)
[ 0.152920] PCI: root bus 00: using default resources
[ 0.152988] PCI host bridge to bus 0000:00
[ 0.152994] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.152998] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.153019] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000
[ 0.153034] pci 0000:00:00.0: reg 10: [mem 0xf0000000-0xf7ffffff pref]
[ 0.153111] pci 0000:00:02.0: [8086:2562] type 00 class 0x030000
[ 0.153131] pci 0000:00:02.0: reg 10: [mem 0xe8000000-0xefffffff pref]
[ 0.153145] pci 0000:00:02.0: reg 14: [mem 0xfeb80000-0xfebfffff]
[ 0.153259] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300
[ 0.153315] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.153360] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300
[ 0.153417] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.153460] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300
[ 0.153516] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.153575] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320
[ 0.153604] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[ 0.153701] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.153729] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[ 0.153786] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100
[ 0.153793] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
[ 0.153794] * this clock source is slow. If you are sure your timer does not have
[ 0.153796] * this bug, please use "acpi_pm_good" to disable the workaround
[ 0.153893] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a
[ 0.153912] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.153927] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.153940] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.153953] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.153968] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.153983] pci 0000:00:1f.1: reg 24: [mem 0xfeb7fc00-0xfeb7ffff]
[ 0.154022] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[ 0.154078] pci 0000:00:1f.3: reg 20: [io 0xeda0-0xedbf]
[ 0.154125] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[ 0.154146] pci 0000:00:1f.5: reg 10: [io 0xee00-0xeeff]
[ 0.154159] pci 0000:00:1f.5: reg 14: [io 0xedc0-0xedff]
[ 0.154171] pci 0000:00:1f.5: reg 18: [mem 0xfeb7fa00-0xfeb7fbff]
[ 0.154184] pci 0000:00:1f.5: reg 1c: [mem 0xfeb7f900-0xfeb7f9ff]
[ 0.154232] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.154283] pci 0000:01:05.0: [14f1:2f20] type 00 class 0x078000
[ 0.154304] pci 0000:01:05.0: reg 10: [mem 0xfe9f0000-0xfe9fffff]
[ 0.154317] pci 0000:01:05.0: reg 14: [io 0xdff8-0xdfff]
[ 0.154382] pci 0000:01:05.0: PME# supported from D3hot D3cold
[ 0.154411] pci 0000:01:09.0: [14e4:4401] type 00 class 0x020000
[ 0.154432] pci 0000:01:09.0: reg 10: [mem 0xfe9ee000-0xfe9effff]
[ 0.154487] pci 0000:01:09.0: reg 30: [mem 0xfea00000-0xfea03fff pref]
[ 0.154510] pci 0000:01:09.0: supports D1 D2
[ 0.154514] pci 0000:01:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.154555] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.154562] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.154569] pci 0000:00:1e.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.154576] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.154580] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.154592] pci_bus 0000:00: on NUMA node 0
[ 0.154599] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.155210] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.155789] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.308575] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.308951] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.309323] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.309697] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.310065] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.310432] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.310801] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.311176] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.311391] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.311406] vgaarb: loaded
[ 0.311409] vgaarb: bridge control possible 0000:00:02.0
[ 0.311463] PCI: Using ACPI for IRQ routing
[ 0.311469] PCI: pci_cache_line_size set to 64 bytes
[ 0.311545] reserve RAM buffer: 000000004fe74000 - 000000004fffffff
[ 0.312049] pnp: PnP ACPI init
[ 0.312069] ACPI: bus type pnp registered
[ 0.315771] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.315777] pnp 00:00: [mem 0x00100000-0x00ffffff]
[ 0.315781] pnp 00:00: [mem 0x01000000-0x4fe73fff]
[ 0.315785] pnp 00:00: [mem 0x000c0000-0x000fffff]
[ 0.315788] pnp 00:00: [mem 0xfec00000-0xfec0ffff]
[ 0.315792] pnp 00:00: [mem 0xfee00000-0xfee0ffff]
[ 0.315796] pnp 00:00: [mem 0xfecf0000-0xfecf0fff]
[ 0.315800] pnp 00:00: [mem 0xffb00000-0xffbfffff]
[ 0.315804] pnp 00:00: [mem 0xffc00000-0xffffffff]
[ 0.315871] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.315878] system 00:00: [mem 0x00100000-0x00ffffff] could not be reserved
[ 0.315884] system 00:00: [mem 0x01000000-0x4fe73fff] could not be reserved
[ 0.315890] system 00:00: [mem 0x000c0000-0x000fffff] could not be reserved
[ 0.315895] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.315900] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.315904] system 00:00: [mem 0xfecf0000-0xfecf0fff] has been reserved
[ 0.315909] system 00:00: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.315914] system 00:00: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.315920] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.317490] pnp 00:01: [bus 00-ff]
[ 0.317495] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.317499] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.317503] pnp 00:01: [io 0x0d00-0xffff window]
[ 0.317508] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.317512] pnp 00:01: [mem 0x80860000-0xfebfffff window]
[ 0.317572] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.319923] pnp 00:02: [io 0x0080-0x009f]
[ 0.319928] pnp 00:02: [io 0x0000-0x001f]
[ 0.319932] pnp 00:02: [io 0x00c0-0x00df]
[ 0.319937] pnp 00:02: [dma 4]
[ 0.319977] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.320097] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.320115] pnp 00:03: [irq 13]
[ 0.320157] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.320265] pnp 00:04: [io 0x0061]
[ 0.320309] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.320416] pnp 00:05: [io 0x0070-0x007f]
[ 0.320426] pnp 00:05: [irq 8]
[ 0.320467] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.323443] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.323448] pnp 00:06: [io 0x03f7]
[ 0.323455] pnp 00:06: [irq 6]
[ 0.323460] pnp 00:06: [dma 2]
[ 0.323717] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.324542] pnp 00:07: [io 0x0060]
[ 0.324547] pnp 00:07: [io 0x0064]
[ 0.324555] pnp 00:07: [irq 1]
[ 0.324608] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.328627] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.328636] pnp 00:08: [irq 4]
[ 0.328849] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.332262] pnp 00:09: [io 0x0378-0x037f]
[ 0.332267] pnp 00:09: [io 0x0778-0x077f]
[ 0.332275] pnp 00:09: [irq 7]
[ 0.332279] pnp 00:09: [dma 0 disabled]
[ 0.332808] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.334507] pnp 00:0a: [io 0x0062-0x0063]
[ 0.334512] pnp 00:0a: [io 0x0065-0x006f]
[ 0.334515] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.334519] pnp 00:0a: [io 0x0800-0x085f]
[ 0.334523] pnp 00:0a: [io 0x0c00-0x0c7f]
[ 0.334526] pnp 00:0a: [io 0x0860-0x08ff]
[ 0.334601] system 00:0a: [io 0x0800-0x085f] has been reserved
[ 0.334607] system 00:0a: [io 0x0c00-0x0c7f] has been reserved
[ 0.334611] system 00:0a: [io 0x0860-0x08ff] has been reserved
[ 0.334617] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.335466] pnp: PnP ACPI: found 11 devices
[ 0.335470] ACPI: ACPI bus type pnp unregistered
[ 0.335476] PnPBIOS: Disabled by ACPI PNP
[ 0.372918] Switching to clocksource acpi_pm
[ 0.372979] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.372986] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.372996] pci 0000:00:1e.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.373021] pci 0000:00:1e.0: setting latency timer to 64
[ 0.373028] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.373033] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.373037] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.373041] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfeafffff]
[ 0.373045] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.373049] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[ 0.373161] NET: Registered protocol family 2
[ 0.373274] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.373674] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.374901] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.375682] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.375688] TCP: reno registered
[ 0.375698] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.375727] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.375966] NET: Registered protocol family 1
[ 0.376004] pci 0000:00:02.0: Boot video device
[ 0.376004] PCI: CLS 0 bytes, default 64
[ 0.376004] Unpacking initramfs...
[ 0.814223] Freeing initrd memory: 14256k freed
[ 0.838369] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[ 0.838377] Simple Boot Flag at 0x7a set to 0x1
[ 0.839019] audit: initializing netlink socket (disabled)
[ 0.839059] type=2000 audit(1485728650.836:1): initialized
[ 0.852128] highmem bounce pool size: 64 pages
[ 0.852138] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.852361] VFS: Disk quotas dquot_6.5.2
[ 0.852401] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.852518] msgmni has been set to 1736
[ 0.852787] alg: No test for stdrng (krng)
[ 0.852837] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.852843] io scheduler noop registered
[ 0.852846] io scheduler deadline registered
[ 0.852870] io scheduler cfq registered (default)
[ 0.853001] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.853031] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.853035] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.853479] GHES: HEST is not enabled!
[ 0.853501] isapnp: Scanning for PnP cards...
[ 1.207679] isapnp: No Plug & Play device found
[ 1.207761] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.228133] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.248851] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.249056] Linux agpgart interface v0.103
[ 1.249164] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 1.249198] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[ 1.249321] agpgart-intel 0000:00:00.0: detected 1024K stolen memory
[ 1.249476] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 1.249664] i8042: PNP: PS/2 Controller [PNP0303:KBD] at 0x60,0x64 irq 1
[ 1.249668] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.250601] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.250752] mousedev: PS/2 mouse device common for all mice
[ 1.250828] rtc_cmos 00:05: RTC can wake from S4
[ 1.250976] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.251004] rtc0: alarms up to one day, 242 bytes nvram
[ 1.251187] TCP: cubic registered
[ 1.251253] NET: Registered protocol family 10
[ 1.251581] Mobile IPv6
[ 1.251587] NET: Registered protocol family 17
[ 1.251595] Registering the dns_resolver key type
[ 1.251676] Using IPI No-Shortcut mode
[ 1.251835] PM: Hibernation image not present or could not be loaded.
[ 1.251859] registered taskstats version 1
[ 1.252280] rtc_cmos 00:05: setting system clock to 2017-01-29 22:24:11 UTC (1485728651)
[ 1.252437] Freeing unused kernel memory: 416k freed
[ 1.253028] Write protecting the kernel text: 3496k
[ 1.253055] Write protecting the kernel read-only data: 984k
[ 1.271988] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.284443] udevd[45]: starting version 175
[ 1.383118] usbcore: registered new interface driver usbfs
[ 1.383163] usbcore: registered new interface driver hub
[ 1.389315] SCSI subsystem initialized
[ 1.389393] usbcore: registered new device driver usb
[ 1.390294] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.390389] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.390396] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.390439] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.390487] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.408580] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.408620] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xffa80800
[ 1.410496] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.420146] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.420234] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.420239] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.420243] usb usb1: Product: EHCI Host Controller
[ 1.420247] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.420251] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.421035] hub 1-0:1.0: USB hub found
[ 1.421047] hub 1-0:1.0: 6 ports detected
[ 1.424966] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.424974] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.424994] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.425056] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000ff80
[ 1.425124] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.425129] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.425133] usb usb2: Product: UHCI Host Controller
[ 1.425136] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.425140] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.425769] hub 2-0:1.0: USB hub found
[ 1.425782] hub 2-0:1.0: 2 ports detected
[ 1.426788] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.426795] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.426810] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.426866] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ff60
[ 1.426931] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.426936] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.426940] usb usb3: Product: UHCI Host Controller
[ 1.426944] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.426947] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.427899] hub 3-0:1.0: USB hub found
[ 1.427910] hub 3-0:1.0: 2 ports detected
[ 1.428285] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.428292] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.428307] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.428361] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.428424] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.428428] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.428432] usb usb4: Product: UHCI Host Controller
[ 1.428435] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.428439] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.428620] hub 4-0:1.0: USB hub found
[ 1.428630] hub 4-0:1.0: 2 ports detected
[ 1.431149] libata version 3.00 loaded.
[ 1.450818] ata_piix 0000:00:1f.1: version 2.13
[ 1.450913] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.457805] scsi0 : ata_piix
[ 1.464089] scsi1 : ata_piix
[ 1.464206] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.464212] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.471125] microcode: CPU0 sig=0xf29, pf=0x4, revision=0x17
[ 1.477694] FDC 0 is a post-1991 82077
[ 1.549063] microcode: CPU0 updated to revision 0x2e, date = 2004-08-11
[ 1.549580] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.637125] ata2.00: ATAPI: GCR-8483B, 1.05, max UDMA/33
[ 1.637135] ata2.01: ATAPI: SAMSUNG CD-R/RW SW-252S, R901, max UDMA/33
[ 1.644590] ata1.00: ATA-6: WDC WD400BB-75FJA1, 14.03G14, max UDMA/100
[ 1.644595] ata1.00: 78125000 sectors, multi 8: LBA
[ 1.652789] ata2.00: configured for UDMA/33
[ 1.660371] ata1.00: configured for UDMA/100
[ 1.660549] scsi 0:0:0:0: Direct-Access ATA WDC WD400BB-75FJ 14.0 PQ: 0 ANSI: 5
[ 1.661193] ata2.01: configured for UDMA/33
[ 1.668125] scsi 1:0:0:0: CD-ROM HL-DT-ST CD-ROM GCR-8483B 1.05 PQ: 0 ANSI: 5
[ 1.669492] scsi 1:0:1:0: CD-ROM SAMSUNG CD-R/RW SW-252S R901 PQ: 0 ANSI: 5
[ 1.688103] ssb: Found chip with id 0x4401, rev 0x01 and package 0x00
[ 1.688114] ssb: Core 0 found: Fast Ethernet (cc 0x806, rev 0x04, vendor 0x4243)
[ 1.688123] ssb: Core 1 found: V90 (cc 0x807, rev 0x01, vendor 0x4243)
[ 1.688130] ssb: Core 2 found: PCI (cc 0x804, rev 0x02, vendor 0x4243)
[ 1.692813] sd 0:0:0:0: [sda] 78125000 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.692928] sd 0:0:0:0: [sda] Write Protect is off
[ 1.692933] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.692983] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.693924] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 1.693932] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.694631] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.698102] sr1: scsi3-mmc drive: 48x/16x writer cd/rw xa/form2 cdda tray
[ 1.698966] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 1.700502] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.700629] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.700745] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 1.728270] ssb: Sonics Silicon Backplane found on PCI device 0000:01:09.0
[ 1.728616] b44: Broadcom 44xx/47xx 10/100 PCI ethernet driver version 2.0
[ 1.731576] sda: sda1 sda2 < sda5 >
[ 1.732190] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.748850] b44 ssb0:0: eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:0f:1f:4e:88:7b
[ 1.848097] Refined TSC clocksource calibration: 2657.812 MHz.
[ 1.848109] Switching to clocksource tsc
[ 1.916044] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[ 2.091818] usb 3-2: New USB device found, idVendor=046d, idProduct=c069
[ 2.091825] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.091830] usb 3-2: Product: USB Laser Mouse
[ 2.091833] usb 3-2: Manufacturer: Logitech
[ 2.125914] input: Logitech USB Laser Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input1
[ 2.126173] generic-usb 0003:046D:C069.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-0000:00:1d.1-2/input0
[ 2.126526] usbcore: registered new interface driver usbhid
[ 2.126531] usbhid: USB HID core driver
[ 7.252361] PM: Starting manual resume from disk
[ 7.252370] PM: Hibernation image partition 8:5 present
[ 7.252373] PM: Looking for hibernation image.
[ 7.252710] PM: Image not found (code -22)
[ 7.252714] PM: Hibernation image not present or could not be loaded.
[ 7.294023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.757799] udevd[311]: starting version 175
[ 10.117704] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 10.117719] ACPI: Power Button [VBTN]
[ 10.118506] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 10.118517] ACPI: Power Button [PWRF]
[ 10.384592] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.391650] parport_pc 00:09: reported by Plug and Play ACPI
[ 10.391705] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 10.400802] intel_rng: FWH not detected
[ 10.520352] iTCO_vendor_support: vendor-support=0
[ 10.521512] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.521624] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0860)
[ 10.523166] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.733259] [drm] Initialized drm 1.1.0 20060810
[ 11.155954] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 11.375845] i915 0000:00:02.0: setting latency timer to 64
[ 11.390153] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 11.390159] [drm] Driver supports precise vblank timestamp query.
[ 11.390231] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 11.396397] [drm] initialized overlay support
[ 11.506392] fbcon: inteldrmfb (fb0) is primary device
[ 11.626945] Console: switching to colour frame buffer device 160x64
[ 11.632709] fb0: inteldrmfb frame buffer device
[ 11.632713] drm: registered panic notifier
[ 11.632726] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 11.632852] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 12.052026] intel8x0_measure_ac97_clock: measured 54672 usecs (2634 samples)
[ 12.052032] intel8x0: clocking to 48000
[ 13.751131] Adding 1631228k swap on /dev/sda5. Priority:-1 extents:1 across:1631228k
[ 13.782025] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.187647] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.462459] loop: module loaded
[ 17.023405] RPC: Registered named UNIX socket transport module.
[ 17.023413] RPC: Registered udp transport module.
[ 17.023416] RPC: Registered tcp transport module.
[ 17.023419] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.071816] FS-Cache: Loaded
[ 17.125071] NFS: Registering the id_resolver key type
[ 17.125112] FS-Cache: Netfs 'nfs' registered for caching
[ 17.152059] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 19.797208] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 22.038608] Bluetooth: Core ver 2.16
[ 22.039016] NET: Registered protocol family 31
[ 22.039023] Bluetooth: HCI device and connection manager initialized
[ 22.039028] Bluetooth: HCI socket layer initialized
[ 22.039031] Bluetooth: L2CAP socket layer initialized
[ 22.039042] Bluetooth: SCO socket layer initialized
[ 22.064271] Bluetooth: RFCOMM TTY layer initialized
[ 22.064282] Bluetooth: RFCOMM socket layer initialized
[ 22.064286] Bluetooth: RFCOMM ver 1.11
[ 22.194173] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.194181] Bluetooth: BNEP filters: protocol multicast
[ 22.207155] lp0: using parport0 (interrupt-driven).
[ 22.521797] ppdev: user-space parallel port driver
[ 24.811064] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 29.534418] [drm] capturing error event; look for more information in /debug/dri/0/i915_error_state
[ 29.538406] render error detected, EIR: 0x00000010
[ 29.538406] [drm:i915_report_and_clear_eir] *ERROR* EIR stuck: 0x00000010, masking
[ 96.275344] I-pipe: head domain RTAI registered.
[ 96.275357] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 96.275367] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 96.275373] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8305630, CLK_FREQ 2658038000, CPU_FREQ 2658038000
[ 96.275378] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 96.275383] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8305630, 8305630, 7703500
[ 96.329496] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 96.329583] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 96.329591] RTAI[sched]: hard timer type/freq = APIC/8305630(Hz); default timing: oneshot; linear timed lists.
[ 96.329596] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2658038000 hz.
[ 96.329600] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 96.356403] RTAI[math]: loaded.
[ 98.134361] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 98.134365] This Message will only display once per session.
[ 98.134367] Run the Latency Test and resolve before continuing.
[ 227.572216] RTAI[math]: unloaded.
[ 227.576564] SCHED releases registered named ALIEN PEDV$D
[ 227.590175] RTAI[malloc]: unloaded.
[ 227.688034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 227.693481] I-pipe: head domain RTAI unregistered.
[ 227.693499] RTAI[hal]: unmounted.
[ 253.048013] [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung
[ 253.068070] render error detected, EIR: 0x00000010
[ 253.068080] [drm:i915_report_and_clear_eir] *ERROR* EIR stuck: 0x00000010, masking
[ 253.068091] render error detected, EIR: 0x00000010
[ 254.776016] [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung
[ 254.776538] [drm:i915_reset] *ERROR* GPU hanging too fast, declaring wedged!
[ 254.776545] [drm:i915_reset] *ERROR* Failed to reset chip.
[ 564.997841] I-pipe: head domain RTAI registered.
[ 564.997855] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 564.997865] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 564.997871] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8305630, CLK_FREQ 2658038000, CPU_FREQ 2658038000
[ 564.997875] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 564.997880] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8305630, 8305630, 8227250
[ 565.020896] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 565.020983] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 565.020991] RTAI[sched]: hard timer type/freq = APIC/8305630(Hz); default timing: oneshot; linear timed lists.
[ 565.020996] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2658038000 hz.
[ 565.021000] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 565.042631] RTAI[math]: loaded.
[ 572.423906] RTAI[math]: unloaded.
[ 572.428328] SCHED releases registered named ALIEN PEDV$D
[ 572.437919] RTAI[malloc]: unloaded.
[ 572.536024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 572.540413] I-pipe: head domain RTAI unregistered.
[ 572.540431] RTAI[hal]: unmounted.
[ 610.226361] I-pipe: head domain RTAI registered.
[ 610.226373] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 610.226382] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 610.226388] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8305630, CLK_FREQ 2658038000, CPU_FREQ 2658038000
[ 610.226393] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 610.226398] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8305630, 8305630, 8223750
[ 610.248847] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 610.248936] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 610.248943] RTAI[sched]: hard timer type/freq = APIC/8305630(Hz); default timing: oneshot; linear timed lists.
[ 610.248949] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2658038000 hz.
[ 610.248952] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 610.270477] RTAI[math]: loaded.
[ 616.503265] RTAI[math]: unloaded.
[ 616.507655] SCHED releases registered named ALIEN PEDV$D
[ 616.516944] RTAI[malloc]: unloaded.
[ 616.616035] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 616.621532] I-pipe: head domain RTAI unregistered.
[ 616.621549] RTAI[hal]: unmounted.
[ 639.246802] I-pipe: head domain RTAI registered.
[ 639.246814] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 639.246825] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 639.246830] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8305630, CLK_FREQ 2658038000, CPU_FREQ 2658038000
[ 639.246835] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 639.246840] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8305630, 8305630, 8224000
[ 639.267063] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 639.267153] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 639.267161] RTAI[sched]: hard timer type/freq = APIC/8305630(Hz); default timing: oneshot; linear timed lists.
[ 639.267167] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2658038000 hz.
[ 639.267171] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 639.292785] RTAI[math]: loaded.
[ 639.507656] GANTRYKINS: joints[0] = 0
[ 639.507665] GANTRYKINS: joints[1] = 1
[ 639.507669] GANTRYKINS: joints[2] = 2
[ 639.507674] GANTRYKINS: joints[3] = 1
[ 639.507678] GANTRYKINS: joints[4] = -1
[ 639.507682] GANTRYKINS: joints[5] = -1
[ 639.507687] GANTRYKINS: joints[6] = -1
[ 639.507691] GANTRYKINS: joints[7] = -1
[ 639.507696] GANTRYKINS: joints[8] = -1
[ 645.009218] RTAI[math]: unloaded.
[ 645.016638] SCHED releases registered named ALIEN PEDV$D
[ 645.026282] RTAI[malloc]: unloaded.
[ 645.124031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 645.128436] I-pipe: head domain RTAI unregistered.
[ 645.128455] RTAI[hal]: unmounted.
Thanks,
Steve
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.0
TASK=milltask
HALUI=
DISPLAY=axis
4609
4653
[ 0.093258] dummy:
30 Jan 2017 16:41 #86979
by steveb48
Replied by steveb48 on topic LinuxCNC exits after launch
Perfect. Thanks. Before I posted my question I searched for "srb->Map" but nothing came. Maybe I was in the wrong forum.
Steve
Steve
Time to create page: 0.174 seconds
