HAL config for linear encoder and stepper motor
04 Mar 2017 21:42 - 04 Mar 2017 21:45 #89008
by mgadid
Replied by mgadid on topic HAL config for linear encoder and stepper motor
finaly found the time to finish the config files (HAL and INI )
added are the HAL and INI configer to run 1 stepper motor with
liniear encoder (puls on phase A only) with Gecko g540 as a driver.
will update apon testing and results.
would love to get feedback on the files (forshour i missed some thing).
Big thanks to Todd and the comunety for shearing info and reply
Last edit: 04 Mar 2017 21:45 by mgadid.
- AlmeidaAlin3
29 Dec 2017 13:23 - 29 Dec 2017 13:32 #103821
by AlmeidaAlin3
Replied by AlmeidaAlin3 on topic HAL config for linear encoder and stepper motor
Hello mgadid!
I'm also trying to do what you did! using encoder with steppers. I'm looked at you file and got some errors, but I think you may already have updated the files, am I right? Could you share your results? May we could work together with this!
thanks!
thanks!
Last edit: 29 Dec 2017 13:32 by AlmeidaAlin3.
30 Dec 2017 22:08 - 30 Dec 2017 22:09 #103878
by mgadid
Hi, i had some errors and fixed them. but i didn't continue with this project.
added are my last files i worked on.
in the file you will find comments that will help you figure what i have done.
it will be great if you publish your finshed file.
good luck,
moshe
good luck,
moshe
Last edit: 30 Dec 2017 22:09 by mgadid.
Time to create page: 0.296 seconds
