LinuxCNC and G Code ripper
- rajsenthil
03 Mar 2017 02:44 #88910
by rajsenthil
LinuxCNC and G Code ripper was created by rajsenthil
I am trying to set the bed level using
g code ripper
based on
nice video on g code ripper
What I do not understand is how linuxcnc (in that video Mach3 was used) corrects itself from the probed data.
After setting the probe at the touch point with the offset, the probe scans at different points. Does this point is stored and linuxcnc corrects itself automatically when it hits at that point?
Or is that video missing some intermediate steps before linuxcnc actually starts the machining?
I am using this swicth for the bed leveling and any inputs is appreciated.
- rajsenthil
04 Mar 2017 15:04 #88992
by rajsenthil
Replied by rajsenthil on topic LinuxCNC and G Code ripper
I found the
document
to answer my question. The command G38.x is used to probe and after successful probing, parameters 5061 to 5069 will be set to the coordinates of X, Y, Z, A, B, C, U, V, W of the location of the controlled point at the time the probe changed state.
Time to create page: 0.169 seconds
