CPU Speed A Factor???
06 Mar 2017 22:53 #89111
by fc60
CPU Speed A Factor??? was created by fc60
Greetings,
Running LinuxCNC 2.5.4 with a 1GHz processor chip.
Created a program cutting a surface that output LOTS of point-to-point data.
Programmed feedrate was 10 inch-per-minute.
Watching the Velocity on Axis, the feed never got much over 2.5 inch-per-minute.
Is it possible the CPU was not able to process the data fast enough?
Cheers,
Dave
Cheers,
Dave
06 Mar 2017 23:09 - 06 Mar 2017 23:10 #89112
Replied by PCW on topic CPU Speed A Factor???
Its more likely that your speed is limited by the trajectory planner and blending
For profiles made of many small segments, you should try adjusting the blending
with G64 Px.xxx
Also LinuxCNC version 2.7 has a new trajectory planner that deals with profiles made with many
small segments better than the old planner, so it may be time to upgrade...
with G64 Px.xxx
Last edit: 06 Mar 2017 23:10 by PCW.
The following user(s) said Thank You: fc60
06 Mar 2017 23:18 #89113
by fc60
Replied by fc60 on topic CPU Speed A Factor???
Greetings,
Ahh, G64!!! Time to dig out the manual and do some reading.
Many thanks,
Dave
Many thanks,
Dave
- Thank you received: 5909
07 Mar 2017 18:13 #89143
Replied by tommylight on topic CPU Speed A Factor???
Also acceleration is a huge factor for that type of jobs.
07 Mar 2017 20:34 - 07 Mar 2017 20:35 #89163
by fc60
Greetings,
The mill is 12x40 inch.
X Y and Z are driven by NEMA42 motors rated at 12N.m
Is there something within LinuxCNC to indicate the acceleration values?
Cheers,
Dave
Cheers,
Dave
Last edit: 07 Mar 2017 20:35 by fc60. Reason: Spelling
07 Mar 2017 20:54 #89166
That must be a very big and heavy machine, so leave the acceleration as is.
You should go with PCW advice and install 2.7
Time to create page: 0.075 seconds
