minimum feed rate
- clayton cramer
09 Mar 2017 19:14 - 09 Mar 2017 20:48 #89281
by clayton cramer
minimum feed rate was created by clayton cramer
I am using a Sherline mill, and it appears that my attempts to reduce the feed rate to .0001 ipm isn't working. There is a MAX_VELOCITY parameter in the INI file set to 25, which does indeed seem to be the true maximum feed rate, but I am not finding a MIN_VELOCITY parameter.
It does appear that the very slow feed rates are working. Curiously, the problem I was having with vibration when g0 z-.14 f.001 went away when I did that that same depth .02" at a time. Ditto for the x and y motions. I would not expect different behavior from doing the move in small increments at the same feed rate.
Last edit: 09 Mar 2017 20:48 by clayton cramer. Reason: more data
- Thank you received: 5923
09 Mar 2017 20:50 #89287
Replied by tommylight on topic minimum feed rate
Add it unde max_velocity or above it.
Time to create page: 0.058 seconds
