Spindle configuration
- Nondepietjes
17 Mar 2017 13:09 - 17 Mar 2017 13:19 #89820
by Nondepietjes
Replied by Nondepietjes on topic Spindle configuration
The spindle drive is a baumuller BKF12 /120/400.
www.baumueller-services.com/de/downloads...erating-instructions
Last edit: 17 Mar 2017 13:19 by Nondepietjes.
17 Mar 2017 13:30 #89822
Replied by andypugh on topic Spindle configuration
OK, that's not a device I know anything about.
Do you see the expected drive signals on the inputs with a multimeter?
- Nondepietjes
17 Mar 2017 13:38 #89823
by Nondepietjes
yes if i send a signal i can measure it.
here is an adjustment of my hal file
17 Mar 2017 13:41 #89824
So, the spindle controller has a valid enable signal and a speed request signal? It seems, then, that HAL is no longer the place to look for the problem?
- Nondepietjes
20 Mar 2017 13:51 #89942
by Nondepietjes
yes, i thing i'm missing a connection but i don't find witch one
20 Mar 2017 13:59 #89943
Does the drive have a fault input? Does it expect to see an encoder or tachometer?
- Nondepietjes
20 Mar 2017 14:34 - 20 Mar 2017 14:36 #89945
by Nondepietjes
Yes, there is an encoder and tacho for feedback. but the encoder is connected correctly. the only thing thas not correct in the document of the drive is the X2 panel.
Last edit: 20 Mar 2017 14:36 by andypugh.
20 Mar 2017 14:38 #89946
"Sie sind nicht authorisiert diesen Vorgang zu tätigen."
Maybe it needs the X2 panel?
- Nondepietjes
20 Mar 2017 14:40 - 20 Mar 2017 14:49 #89947
by Nondepietjes
Yes i think so. but the X2 panel in the document is not the same as on my machine. X1 panel is correct
Last edit: 20 Mar 2017 14:49 by Nondepietjes.
20 Mar 2017 14:53 #89948
Any red LEDs?
Time to create page: 0.081 seconds
