huanyang vfd won't communicate get errors.
21 Mar 2017 20:08 #90029
Is that what you see with the -g (debug) option turned on in the driver?
Replied by andypugh on topic huanyang vfd won't communicate get errors.
Gold Border,
Tried getting rid of -p did not use stop bits. When parity is removed it appears that hy_vfd defaults to even parity. I tried all three combinations the same result. The data that hy_vfd is sending over and over appears to be
0x01 0x01 0x0B 0x2c 0x30 or decimal 01 01 13 44 48. Thanks
22 Mar 2017 02:18 #90044
by jcloase
Replied by jcloase on topic huanyang vfd won't communicate get errors.
That is what I see monitoring the RS485 with a third pc. It is what hy_vfd is sending over and over about one a second..
22 Mar 2017 09:17 #90050
So, is there any output from hy_vfd with debugging turned on?
22 Mar 2017 12:03 #90062
by jcloase
Andy,
Can you explain how to turn on debugging.
22 Mar 2017 12:45 #90067
by jcloase
Gentlemen,
I am pretty sure I have figured out what is wrong. I found a thread about missing RS485 chips on MACH support. I checked and I have no chip in my vfd. I ordered some and will let you all know after I install it.
Thanks for all your efforts
22 Mar 2017 14:45 #90072
Use the -g switch in the loadusr line, as described in the manual page.
linuxcnc.org/docs/2.7/html/man/man1/hy_vfd.1.html
Andy,
22 Mar 2017 17:20 #90081
by jcloase
Thanks!
25 Mar 2017 15:11 #90250
by jcloase
Put the RS485 IC in the vfd and still no comms. I've beat this dead horse long enough I give up.
25 Mar 2017 16:28 #90251
eBay has many adverts saying that they sell genuine HY VFDs and to beware of fakes.
www.ebay.co.uk/itm/110V-VARIABLE-FREQUEN...4:g:mTMAAOSwd0BVxE~g
Shows the differences. Which is yours?
25 Mar 2017 20:27 #90259
by jcloase
It's the real thing. I have had it form 6 or 7 years and there was no RS485 IC in it.. I don't know if the software to work with it is in this one. Maybe I'lll buy and new one. I can see hy_vfd putting data out but the vfd just doesn't answer.
Time to create page: 0.176 seconds
