Hydraulic chuck on lathe
- Nondepietjes
27 Mar 2017 13:31 #90368
by Nondepietjes
Hydraulic chuck on lathe was created by Nondepietjes
hi,
Can i use Linuxcnc to opperate a hydraulic chusk and how do i connect it and with witch signals?
Thanks in advance
Thanks in advance
27 Mar 2017 14:25 #90372
Replied by andypugh on topic Hydraulic chuck on lathe
Yes, and one (of many) ways to do it is in the user-defined M-code section:
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m100-m199
The following user(s) said Thank You: Nondepietjes
- Nondepietjes
28 Mar 2017 13:02 #90438
by Nondepietjes
Replied by Nondepietjes on topic Hydraulic chuck on lathe
Yes oke, but how do i know witch valve and witch sensor and witch contact i have to connect to my 7i77 board.
28 Mar 2017 13:07 #90439
Do you have any documentation for the machine?
- Nondepietjes
28 Mar 2017 13:16 #90440
by Nondepietjes
Thats the problem i don't. it's a machine bought without any documentation so i have to search everything.
But there are two inductive sensors.
one directional control valve.
and two pressure switches.
If you prefere some picture let me know
28 Mar 2017 15:06 #90445
I think the first thing to do is to experiment with a physical switch and see what it takes to operate the hardware before trying to run it from software.
Time to create page: 0.121 seconds
