What do I need to add to turn threads
30 Mar 2017 17:36 #90584
by MAG45
Replied by MAG45 on topic What do I need to add to turn threads
no, its a BoB kit my friend assembled himself, and the suspected source of the problems i have been facing. I bought a cnc4pc c-10 to replace it.
not sure of the ratio to spindle of the gears, i will see if i can figure it out
30 Mar 2017 17:44 #90585
It says "Mesa 7i43" on it.....
Just rotate the spindle by hand and watch.
Replied by andypugh on topic What do I need to add to turn threads
30 Mar 2017 17:54 #90586
by MAG45
they are completely disengaged and free spinning
30 Mar 2017 18:03 #90587
Is there an internal clutch or something? I was assuming they were driven from something inside the headstock, but perhaps that is not the case.
30 Mar 2017 18:13 #90589
by MAG45
I believe it used to be, i think the internals were remove by my friend when converting it. I was in a wheelchair at the time and couldnt really get in to see what he was doing.
My initial plan was to pull the main pulley off and make and aluminum slotted disk that slides on the drive shaft before the pulley to use for the sensor(s). I need to find whatever sensors I need first so i can figure out where i can mount them and what diameter to make the slotted disk.
30 Mar 2017 18:22 #90593
You could leave the pulley in place:
ve7it.cowlug.org/spindle-encoder.html
And it will be worth seeing if the 7i43 works, it's a better solution than the C10 in some ways. (You could use the C10 as a breakout for the 7i43, actually, with a bit of cabling)
30 Mar 2017 18:26 #90596
by MAG45
thanks for the link, looks like a good read for me.
I am so lost on the wiring, or how i would use the c-10 and the 7i43 together. I have had the c-10 a year and have read the instruction 100 times, but still scared to swap it out.
03 Apr 2017 01:32 #90785
by MAG45
Taking out the stuff in there that was never connected and there was infact a mesa 7i43 hiding in there. never been used for anything, i dont know why its there.
03 Apr 2017 09:33 #90790
It is probably worth trying to use it, it will allow you to have a higher-count spindle encoder than is possible with just the parallel port.
You will need one of these adaptors to connect between the parallel-port cable and the 7i43.
www.amazon.co.uk/Motherboard-Parallel-Pr...socket/dp/B00PI5XF4U
Or your local equivalent.
Time to create page: 0.079 seconds
