Dibean linuxcnc
25 Apr 2017 09:05 #92038
by nissjay
Dibean linuxcnc was created by nissjay
Hi All,
I recently down loaded and installed new copy of linuxcnc (one week ago) but as my old linuxcnc was on UBUNTU I used GEDIT to edit G codes.But new version is on DIBEAN I can not find any g code editing program.
As such please some one let me know.
1. How to download and install the g code editor for Dibean ?
2. How to download and iinstall Cad/Cam program which reliably works with linuxcnc?
Nissan
Nissan
- Thank you received: 1369
25 Apr 2017 13:40 #92055
Replied by Todd Zuercher on topic Dibean linuxcnc
You can use any text editor to edit g-code. Gedit, is the text editor bundled with the Gnome desktop environment. If you choose to you can install it with Synaptic or apt-get install gedit. But it will have to install a lot of other software. The are one or two text editors that come with the new Linuxcnc ISO. I think it is called Mousepad and there are many others that you could install. If you search ini file for your Linuxcnc configuration for "gedit" then replace "gedit" with "mousepad" and save it then when you select edit g-dode in the axis menu it will open the file with Mousepad instead of Gedit.
25 Apr 2017 16:56 #92080
Replied by andypugh on topic Dibean linuxcnc
I don't like Mousepad, and gedit installs _far_ too many dependencies.
I have recently started using Geany, and I like it for code editing, it is pretty much a complete IDE.
26 Apr 2017 00:42 #92114
by nissjay
Replied by nissjay on topic Dibean linuxcnc
Hi Andypugh,
Please let me know how to install it step by step.
Nissjay
Nissjay
26 Apr 2017 02:15 #92117
from the command lineor use Synaptic.
sudo apt-get install geany
26 Apr 2017 10:31 #92125
X 2 Andy, I'm not even sure how I found it but I get annoyed if a file opens in gedit now after only a week. I've kinda noticed you can tie it to a compiler but I have not tried that
Replied by rodw on topic Dibean linuxcnc
Time to create page: 0.153 seconds
