Home button doesn't work
03 May 2017 11:56 #92569
by timmert
Home button doesn't work was created by timmert
Hello
I busy converting a manual lathe to linuxcnc. So far all good...but now I reached the electronics part.
Home switches are connected.
If I check with HAL-meter both switches are working fine.
I first setup the X-axis. And it's fully working and homes.
But somehow when I press the home button for the Z-axis nothing happens.
It has exactly the same home settings as the X-axis. Except for the home sequence value (2 instead of 1)
Any ideas what could cause this?
I use the Gmoccapy gui.
04 May 2017 14:22 #92643
Replied by andypugh on topic Home button doesn't work
Which LinuxCNC version? Which GUI?
Does "Home All" work?
I am wondering if it is trying to home a non-existent Y axis. I think I recall seeing that once.
09 May 2017 13:17 #92922
by timmert
Replied by timmert on topic Home button doesn't work
In was running 2.8.x
I switched back to 2.7, and everything is working fine
Time to create page: 0.098 seconds
