7i76e
18 May 2017 16:46 #93357 by Diederik
Diederik created the topic: 7i76e
I have a 7i76e card, that I'm using for a robot, and I now want to add a 6th axis/joint to the 7i76e. I got a cheap parallel breakout card, which I want to link to the expansion connector P1. In GPIO, I can read inputs, but I would like to use P2,P3,P4,P5 on parallel breakout board for step/dir. I did not succeed trying to link gpio, and suspect I will need some firmware to assign P2-P5 to StepGen's.
I suspect the mesanet link doesn't work? www.mesanet.com/software/ ... ? I want to see what options is available. Any suggestions are welcome please.
Regards,
Diekie
18 May 2017 18:37 #93360 by PCW
PCW replied the topic: 7i76e
www.mesanet.com/7i76e_7i76x1_bstechx2d.bit
Is a 7I76e config that supports 2X of the common 5 Axis parallel port breakouts on the expansion connectors
for a total of 15 stepgen channels. It should also work with other parallel port breakouts for step/dir only
Made for this type of breakout:
www.ebay.com/itm/5-Axis-CNC-Breakout-Boa...3:g:4EMAAOSwtfhYq6sZ
The following user(s) said Thank You: Diederik
27 May 2017 09:33 #93700 by Diederik
Diederik replied the topic: 7i76e
Hi Peter,
Thank you for the Firmware, It worked well. The problem with the link was from my internet provider, I used a different internet service, then I could access the link. Thank you very much for your help.
Time to create page: 0.095 seconds
