- General
- General LinuxCNC Questions
- Is there some place i can learn basic linux operations needed to use linuxcnc?
- Prad.Linuxcnc
21 May 2017 11:39 #93427
by Prad.Linuxcnc
Is there some place i can learn basic linux operations needed to use linuxcnc? was created by Prad.Linuxcnc
I have installed LinuxCNC and use it to run my VMC, but i now i need to know how to perform basic tasks like changing the date,time and installing apps like HeeksCAD and a calculator. which is the best way to learn this stuff?
- Thank you received: 1369
21 May 2017 12:51 #93430
Replied by Todd Zuercher on topic Is there some place i can learn basic linux operations needed to use linuxcnc?
googline your questions, and just messing about with it, are the best ways to learn.
- Prad.Linuxcnc
21 May 2017 18:21 #93446
by Prad.Linuxcnc
Replied by Prad.Linuxcnc on topic Is there some place i can learn basic linux operations needed to use linuxcnc?
Ah i tried...is there a GUI to install applications? Hell i couldnt change the date and time uaing the terminal bcos of some permission issue. Ok thanks
21 May 2017 18:30 #93447
Look for synaptic package manager. It will know about most standard programs but to use something like heekscad you are jumping in a lot deeper to get it installed but their git seems to have the instructions step by step.
github.com/Heeks/heekscnc
Replied by rodw on topic Is there some place i can learn basic linux operations needed to use linuxcnc?
22 May 2017 14:33 #93479
To change system settings (rather than user settings) you typically have to use the "sudo" command to temporarily use admin privileges.
sudo date --set="22 MAY 2017 15:32:00"
Replied by andypugh on topic Is there some place i can learn basic linux operations needed to use linuxcnc?
- General
Time to create page: 0.120 seconds
