E-Stop In vs E-Stop Out
27 May 2017 16:51 - 27 May 2017 16:51 #93711
by dewayne
E-Stop In vs E-Stop Out was created by dewayne
I have configure the Mesa 7i76 to connect an external E-Stop IN.
That works.
What about E-StopOUT does it follow the E-Stop Button. When I press ESTOP should I expect to see ESTOP-OUT change State.
What I was trying to do was to Press Estop and Estop-OUT would respond back by activating a relay and also turning ON the light in the ESTOP Button.
Thankyou
That works.
Thankyou
Last edit: 27 May 2017 16:51 by dewayne.
- Thank you received: 5872
27 May 2017 22:20 #93722
Replied by tommylight on topic E-Stop In vs E-Stop Out
Yes and yes.
That is how it is supposed to work.
The following user(s) said Thank You: dewayne
29 May 2017 09:53 #93775
Replied by rodw on topic E-Stop In vs E-Stop Out
Heres a recent example with 3 different estop signals I worked out
forum.linuxcnc.org/10-advanced-configura...tches?start=10#93394
Time to create page: 0.422 seconds
