Gantry Homing
- e76nystrom
05 Jun 2017 23:16 #94128
by e76nystrom
Gantry Homing was created by e76nystrom
I have a CNC router that I have been running on a parallel port and am trying to convert it use the Mesa 5i25. I used some custom software to implement gantry squaring for the parallel port. The scheme I used will not work using the 5i25.
I found the following thread www.forum.linuxcnc.org/38-general-linuxc...1013-ja14-not-homing and have tried to modify hal and ini files to match the examples I found.
I am running master 2.8.0~pre1.
My router joint configuration is xyyza. When I load the attached configuration and try jogging, the x axis works properly.
When I try the y axis only the first motor moves. When I try the z axis I get a joint2 follow error.
Is the JointAxis code in the current master build or do I need to build another branch to get that?
Any ideas of things to try
06 Jun 2017 02:22 - 06 Jun 2017 02:22 #94130
Replied by PCW on topic Gantry Homing
Y2 is missing the PID component connections (and the Y2 PID component)
Not sure what's wrong with Z at first glance
Last edit: 06 Jun 2017 02:22 by PCW.
06 Jun 2017 09:49 #94131
Replied by rodw on topic Gantry Homing
Joint axis is built into master. You don't need to do any custom code. Just set the homing offsets on your Y joints to be -1 (has to be negative and have to be the same) and then use the homing offsets to square the gantry in software when it homes.
- e76nystrom
06 Jun 2017 21:50 #94205
by e76nystrom
Replied by e76nystrom on topic Gantry Homing
Thanks for the help.
I got it working. I added the pid section to the second y axis. That fixed the z axis error because the z axis jogs the second y axis before it is homed. I found the Joint Axis documentation and fixed a couple of minor things in the ini file. I added HOME_OFFSETS to my y and y2 axis. My home switches are aligned so the offsets are the same for now. I moved one axis out of alignment and tested that it aligns properly.
I have attached the updated files as a current working example.
18 Jul 2017 19:11 #96016
by Yannis
Replied by Yannis on topic Gantry Homing
Hi
I try to set the same gantry router except the A axis(i have C axis)
what mesa card do you use?
thanks
Yannis
thanks
Yannis
Time to create page: 0.173 seconds
