Huanyang VFD inverter modbus base frequency
24 Jun 2017 12:52 #94888
by Handy8000
Replied by Handy8000 on topic Huanyang VFD inverter modbus base frequency
@Seb I downloaded and installed the buildbot.linuxcnc.org/dists/wheezy/scrat...req~4e66ee1_i386.deb file and can see the Base ferquency and motor poles in the Hal meter ok.
Can the value be written to the VFD from Hal like the other command strings used to setup the inverter, my custom.hal file uses this command stringIs there a command for use with the base frequency and motor poles?
loadusr -Wn spindle-vfd hy_vfd -n spindle-vfd -t 1 -d /dev/ttyUSB0 -p none -r 38400 -s 1 -f 120 -F 400 -V 220 -I 7.0 -S 24000
- seb_kuzminsky
- Thank you received: 14
24 Jun 2017 15:13 - 24 Jun 2017 15:16 #94890
by seb_kuzminsky
Replied by seb_kuzminsky on topic Huanyang VFD inverter modbus base frequency
Thanks for testing!
You can set the base frequency from the command line with --base-frequency or -B, and motor poles with --motor-poles or -P .
Last edit: 24 Jun 2017 15:16 by seb_kuzminsky.
The following user(s) said Thank You: Handy8000
- seb_kuzminsky
28 Jun 2017 15:12 #95108
by seb_kuzminsky
@Handy8000, is the setting of those parameters working for you as expected?
29 Jul 2017 20:10 #96659
by Handy8000
@Seb Sorry for the delay in replying.
Yes. As far as I can tell, I havent had any issue since installing the deb file.
Thanks.
Thanks.
Time to create page: 0.078 seconds
